Thread: A6 2.5 Tdi Se (abs & Esp Lights)
Results 1 to 8 of 8
  1. A6 2.5 Tdi Se (abs & Esp Lights)
    My 52 reg has developed an intermittent fault. The ABS and ESP dash lights come on most of the time occasionally going out for 4-5 miles. I've had a reputable independent specialist look at it. Their diagnostic equipment pointed them in the direction of the ABS switch but this didn't solve the problem. Pads etc. are all fine.
    Any one else had this problem? They are starting to talk of the ABS pump, which I'm told is big bucks, but is this generally a problem on a car with 82k on the clock?
    Regards,
    Del
  2. Re: A6 2.5 Tdi Se (abs & Esp Lights)
    Jul 2007
    Cheshire, or my A6
    This normally happens when a brake light is out, but it's normally on or off, not intermittent. You could check your bulbs though, just in case.
    Paul
  3. Re: A6 2.5 Tdi Se (abs & Esp Lights)
    london/ UK
    Did you have any work done on the car recently, eg.: brakes, suspension arms, shocks ? If the fault point to an abs sensor, then it might be that one is out of sinc with the rest or its not pluugged in properly, also are the front/rear tyres the same rolling radius/make ? Can you scan the cars memory and post the fault code on the forum ?
  4. Re: A6 2.5 Tdi Se (abs & Esp Lights)
    Aug 2007
    Hook Hampshire
    21 Post(s)
    Had the same problem and it turned out to be the brake light switch which is a pig to replace because it has to be turned a ful 90 degrees in situ. You may find that the brake lights don't work or stay on. I can't remember. Regards
    Audi A7 3.0TDi 2011 160k miles, engine code CLAB 204bhp 2WD
  5. Re: A6 2.5 Tdi Se (abs & Esp Lights)
    Jul 2007
    Norfolk
    I had same problem, did the warning lights come on just after you put your foot on the brake? my ABS/ESP/level control on my allroad was all due to the brake light switch, but i used vag-com to diagnose that.Only cost about £10 or so, and that was from a ***********.....
  6. Re: A6 2.5 Tdi Se (abs & Esp Lights)
    Hi all
    Thanks for your help so far. The fault code is 01435 Brake Pressure Sender. That has been replaced as has the brake light switch. ESP and ASB lights are still coming on though.
    If I am heavy and abrupt on the brakes the fault doesn't seem to occur so readily. Light pressure braking seems to instantly bring the problem on. Interestingly it appears to be when I'm coming off the brakes when the lights come on.
    Regards,
    Del
  7. Re: A6 2.5 Tdi Se (abs & Esp Lights)
    Aug 2007
    Hook Hampshire
    21 Post(s)
    Can you confirm that the brake lights work perfectly. Please check.
  8. Re: A6 2.5 Tdi Se (abs & Esp Lights)
    Jul 2007
    Cheshire, or my A6
    Quote Originally Posted by shabazmo View Post
    DO the above, please!
    Paul
  1. Led Lights In Front Light Unit Or Fog Lights???
    By bigbadsexy in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 18-09-2009, 07:28 PM
  2. led side lights and number plate lights, not working
    By adamk in forum Audi A3 - Archive Topics
    Last Post: 02-04-2008, 07:37 PM
  3. Rear lights and front lights
    Last Post: 08-03-2008, 08:27 PM
  4. Puddle Lights and courtesy lights not working
    By PerArdua in forum Passat - B5 Forum - 1997 -2005
    Last Post: 15-01-2008, 01:43 PM
