Thread: converting headlamps on Avant to European regs
  1. converting headlamps on Avant to European regs
    yardheater Guest
    Hi, I just joined and need some advice on whether I can convert rhd headlamp beams to lhd to drive in Poland (where I have moved to). Audi here have said I have to change the lamp housing all together and charge me a fortune for the privilege, but I am sure there is another way. Please help me save some time and money. Had to change them for UK when I brought the car back from Turkey so don't want to have to buy yet another set of lights.
    Dec 2006
    Hi there
    it can not be done useless you have HID's on the B6..
    You will after get a replacement for LHD.. unless you just want to run them on a low setting...however if your living there you will have to sort them
    RickT
    Oct 2006
    I thought all 'projector' type headlights had a lever which is basically 'flipped' and it angles the beam to the right. This was the case on my MG ZT and the Hymer motorhome.
    Dec 2006
    well i had the headlights out and tried to do it.. even tried taking the housing out and outting it in the other way... would not work...
    As i said this can be done on the ones with HID's tho.
    RickT
    Oct 2006
    Just checked, as you say, only Xenons have the lever. the rest need the plastic deflector sticker.
  1. Converting Headlamps for trip to France
    By Martin S in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 23-07-2007, 11:21 PM
  2. Golf MK4 Headlamps and driving in France
    By kenC in forum Golf MK4 - 1999 - 2004
    Last Post: 08-06-2007, 11:02 PM
  3. 100 avant
    By alfapseud in forum 100 - 200 - Turbo - 100 S4
    Last Post: 23-05-2007, 09:15 PM
  4. Vaux Noob Needs Converting...
    By C9SRi in forum New Member Introductions
    Last Post: 04-05-2007, 12:34 AM
  5. EU Driving - Headlamps
    By brijvs in forum Touran - Sharan - Caravelle
    Last Post: 31-03-2007, 01:33 PM
