Thread: Polo Engine Cutting Out
  1. Smile Polo Engine Cutting Out
    Dec 2006
    Hi all I am a new member with a problem (Most are i guess)
    Have Polo 1.4cl 1997 R reg
    If i start up on the drive idle speed is fine hot or cold.
    If i drive say 50 yds to a junction and dip the clutch the engine cuts out.
    This happens on most occassions.
    If the engine does not cut out, i notice the idle speed drop to approx 800 rpm then rise to 1000 rpm and will oscillate between these speeds until settling at approx 900rpm. This will take approx 4-5 secs.
    If the drop is to below 800 rpm then engine cuts out.
    Any help would be appreciated
  2. Re: Polo Engine Cutting Out
    hi i also have this sort of idle problem on my 1.3i 95 polo i have looked on this site and found out that you may need to clean the throttle body with some carb cleaner.
  3. Re: Polo Engine Cutting Out
    135 Post(s)
    2043 Post(s)
    Hello to you both. The dirty throttle body is the usually cause of cutting out problems and is well within the scope of most DIY enthusiast to carry out. However it must be cleaned gently to avoid any internal scratching of the body and butterfly and after reinstallation the throttle will need to be re-adapted to the ECU so the ECU can learn the TB's new closed position, otherwise you may end up with the idle at around 1500 rpm. It is also an advantage to have the ECU's learnt values erased. You will probably have guessed that you need a diagnostic system such as a registered copy of VAG-COM to do these last two steps.
  4. Re: Polo Engine Cutting Out
    Jun 2010
    Bridgnorth england
    clutch is going
  5. Re: Polo Engine Cutting Out
    Quote Originally Posted by Rob1uk View Post
    clutch is going
    thanks for that Rob, I should imagine after over 3 years he's probably resolved this.
  1. Audi A6 2.0 8v Engine Cutting
    By Kev.trebuan in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 03-05-2011, 10:50 PM
  2. A4 Engine cutting out
    By Bigduke in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 22-08-2007, 01:06 PM
  3. 1.6 16v engine violenlty cutting out while driving
    By Joe.p in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 30-07-2007, 08:38 PM
  4. cutting out polo
    By newboy in forum Polo - Derby - Lupo - Fox
    Last Post: 28-05-2007, 09:20 PM
  5. Bora engine cutting out
    By kas in forum Bora - 1998 - 2005
    Last Post: 07-06-2006, 03:14 PM
