Thread: cured poor idle
Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
  1. tdi loosing power audi a3 2001
    Dec 2008
    Hi wondering if the enthusiasts can help me. Own a3 1.9 tdi 2001. basically its idle at times (stick vaines?) especially on hills with full acceleration. Read on forum, power booster spray (also known as air inlet spray cleaner)to be sprayed on to inlet after maf or unit control arm and let it run in to turbine housing...under diagnostic it came up with error 17965 posotive pressure deviation problem.
    stated in forum -
    IIRC in england it is called 10k diesel booster,,,
    What I fear is the debris falling into the engine or getting stuck with the valves,,,
    so im worried if the spray will go in to debris and wondered if you had any knowledge towards the above.
    imran
  2. Re: cured poor idle
    Dec 2008
    stated in forum -
    imran
    Edit/Delete Message
  3. Re: cured poor idle
    Dec 2008
    I don't think it should be necessary to remove the TB. I had this problem with my 1.8 and took off air pipes up to the throttle body and then with engine running and revved up I sprayed copious amounts of carb cleaner into TB up to point of near stalling engine and after about a minute of this it shone like new. Put all hoses back on and idle as normal and a much smoother engine too.
  1. poor idle
    By lee07 in forum Golf MK4 - 1999 - 2004
    Last Post: 11-11-2007, 07:29 PM
  2. poor idle oil pressure light
    By dyte in forum Golf MK2 - 1984 - 1992
    Last Post: 10-11-2007, 11:10 PM
  3. Poor idle on tdi when cold
    By tezray in forum Archive posts
    Last Post: 15-09-2007, 03:20 PM
  4. 1.8t a3 running rough poor idle no power???
    By djglovehead in forum Audi A3 - Archive Topics
    Last Post: 10-04-2007, 06:33 PM
  5. Sick Golf GT 150 Pd TDi. Power loss, poor idle
    By lchris21 in forum Archive posts
    Last Post: 17-12-2006, 09:02 PM
