Thread: Boot won't lock
Results 1 to 10 of 11
  1. Boot won't lock
    The boot on my R reg Passat estate will no longer lock. Even if I put the key in the boot lock and turn it, the doors will lock and unlock but not the boot. If I open the boot with the doors locked, the alarm sounds. I suspect that the problem is with the solenoid. Anybody else experienced this? Is the solenoid likely to be the cause? Thanks in advance.
  2. Re: Boot won't lock
    more then likely the solenoid is knackered.just double check the catch on the lock with the screwdriver when boot is open.If is not catching,its defo the soleniod.I have replaced hundreds of them
  3. Re: Boot won't lock
    I'll do that. Thanks.
  4. Re: Boot won't lock
    I have the same problem with my Passat saloon, how much does the solenoid cost & is it easy to replace.
    cheers
  5. Re: Boot won't lock
    Quote Originally Posted by kojack View Post
    cheers
    the motor at the boot might be gone. Disconnect the motor from the rest in the boot and it will lock the boot when you turn the key. It wont lock the boot when you turn the key on the doors though.
  6. Re: Boot won't lock
    Cheers thanks dahri, I'll give it a try
  7. Re: Boot won't lock
    Aug 2007
    My solenoid/motor was fully extended when I took it apart after experiencing the same problem. Replaced it for £10 from the ********.
    Took the old one apart and found it working fine so put it back togther and it stil works fine out of the car. I am none the wiser why the problem happened in the first place apart from having to adjust the linkage slightly (simple) when the new one was fitted.
  8. Re: Boot won't lock
    Quote Originally Posted by dahri View Post
    Sounded easy, I don't really no what IM looking for, Ive looked both rear left & right for the boot motor, is it in the boot lid it self ?
    I found a little square blue box in the drivers side rear boot just in front of the tail light but Its written in german, it could be just the rear lights for all I know.
    Im a noob now days, the 70's & 80's was much easier to reapair cars,
  9. Re: Boot won't lock
    Aug 2007
    the motor is mounted inside the lid and accessible once you remove the lid lining. You will find a plastic plate with various linkages and the rectangular motor mounted to it by two screws. I took the whole thing out but realise now that I could have extracted the motor without doing so. It is a simple changeover and the hardest part is probably getting your fingers behind the lining if it is anything like my estate.
    The motor was £10 odd from the ********
  10. Re: Boot won't lock
    Excellent cheers thanks for the help, Passing, I'll have a good look on my next day off.
    Many thanks
  1. boot lock
    By Gt_Tdi_rich in forum Golf MK4 - 1999 - 2004
    Last Post: 13-01-2009, 11:14 AM
  2. My boot won't lock
    By Hermal in forum Passat - B5 Forum - 1997 -2005
    Last Post: 27-03-2008, 01:24 PM
  3. Boot Lock
    By citizenkane in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 18-01-2008, 07:53 PM
  4. Boot Won't Lock
    By new to vw in forum Passat - Archive Topics
    Last Post: 20-03-2007, 06:18 PM
  5. Passat Boot Lock doesn`t Lock
    By Graeme H in forum Passat - Archive Topics
    Last Post: 10-03-2006, 11:34 AM
