Thread: power cable connection help needed
  1. power cable connection help needed
    hi i was wandering if anybody could tell me if there is an easy way of connecting my amp power lead to my battery. ive got a 2001 passat v5, 600w in phase amp and a sony xplod sub. ive been told that you can connect the power lead to a fuse box under the steering collum or to the 12v socket in the boot which would be perfect as i cant see a logical way to run it from the battery as there is so much stuff in the way covered by ducting. Any help would be much appreciated.
    thanks
    neal
    Last edited by PassatV5Neal; 17-04-2008 at 05:47 PM. Reason: didnt get my point across
  2. Re: power cable connection help needed
    Kent
    Whatever you do dont connect it to the lighter socket in the boot they are probably rated at about 5 amp (have a look at the fuse(s) on your amp to see what its rated at and you'll see why you shouldnt use the lighter) - The safest way is straight to the battery with a fuse before it goes through the bulkhead.
    Not too sure how to get the cable thorugh though mate as have only fitted head units or hands frees to Passats
  3. Re: power cable connection help needed
    ok mate thanks for the heads up. ill look into it, hopefully its not too much of a pain in the ***.
    thanks again.
    neal
  1. I-pod Connection
    By Martin S in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 26-11-2012, 10:03 PM
  2. Amp Power Cable!!
    By ss.raju-golf4 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-03-2008, 09:29 PM
  3. Best route for audio power cable?
    By orion1210 in forum Audi A3 - Archive Topics
    Last Post: 02-03-2008, 04:25 PM
  4. MP3 Connection
    By judian2462 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-06-2007, 06:44 PM
  5. 1.9 Tdi- Tune Up- More POWER! Help and ideas needed!
    By Jum1 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-05-2007, 06:50 PM
