Thread: Removing Cubby Hole.
Results 1 to 9 of 9
  1. Removing Cubby Hole.
    Hi there all
    I have just won a 6 disc cd player from fleabay, it is the type that is mounted in the dashboard rather than the remote changer in the boot.-- My question is how to remove the "cubby hole" used for general storage mounted above the standard Gamma radio. It appears to have no screws etc holding it in so i assume that you try to prise it out with a screwdriver or something similar.
    Just want to check with you guys before i force it out and break something.
    Regards
    Chris.
  2. Re: Removing Cubby Hole.
    Bath, Somerset
    You have to remove the stereo first (which you will have to do anyway to connect the CD, then the starage compartment should come out easily.
  3. Re: Removing Cubby Hole.
    Ok, thanks for that- better get myself a removal tool then!!!
  4. Re: Removing Cubby Hole.
    you might also need the spacer plate to sit between the changer and the tape player / main unit
    1.8T AUQ head standard engine. Newsouth performance Boost, Oil pressure and Temperature gauges, 6 spoke TT alloys and A8 interior light.
    Next engine
  5. Re: Removing Cubby Hole.
    Yep, thanks for that, the spacer and removal tool came with the cd player, did not check all the items in the box at first !! thanks for your help, have removed the cubby hole now and fitted the cd player, only trouble is that the illumination does not work- my Bora does not have the separate 2 pin plug from the loom to power it, I saw a thread that mentioned an aftermarket product that would sort this out but cannot find the tread now !!
    Regards
    Chris.
  6. Re: Removing Cubby Hole.
    ok just went and got my gamma radio and 6 disc outo the cupboard
    on the radio are 3 plugs starting at the bottom there is the iso power connection
    in the middle speaker connection
    then at the top there is the multi connection ( yellow green and blue ) the blue is the changer. the yellow i believe is an amp connection. the green ????
    the only illumination is through the power connection ( usually an orange colour but im not 100% ) you might just have to run a wire from your dimmer switch to the power connection. if theres not one there an adaptor cable for a vauxhall should do as its just an extension cable
    what is this 2 pin connector your on about ?
    i know when i installed my own cd player and done away with the gamma and changer i had to cut the illumination wire and wire it directly to the headunit as it had a separate wire for illumination
    Next engine
  7. Red face Re: Removing Cubby Hole.
    ignore me ive just found it its on the changer itself and not the radio unit.
    it must be floating around the back of my central console
    sorry
    Next engine
  8. Re: Removing Cubby Hole.
    Ok thanks for your help and digging all your old gear out !! Do you have any idea where this power supply may be hidden or might it not be there at all in my model (2.0 S) i would be surprised if VW made several different looms.
    Regards
    Chris.
  9. Re: Removing Cubby Hole.
    ive no idea mate it must still be floating around the back of my central console. would say it would be just a wire from the illumination lead and and an earth connection but dont quote me on this
    Next engine
  1. Curious hole under the dash
    By chalkie in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-03-2008, 09:26 PM
  2. Drainage Hole Near ECU?
    By Mitch22 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 15-02-2008, 03:11 PM
  3. Cant find hole in firewall help?
    By WhiteChrome in forum Golf MK5 - 2004 - 2009
    Last Post: 17-01-2008, 01:27 AM
  4. Hole in gear box, is this common?
    By sim69bed in forum Golf MK4 - 1999 - 2004
    Last Post: 08-11-2007, 10:29 PM
  5. Drainage hole behind ecu box a4
    By abaker in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 19-09-2006, 11:54 AM
