Thread: Golf mk 3 rear left engine mount change
  1. Golf mk 3 rear left engine mount change
    Feb 2007
    Hi hoping someone can give some advice on changing the engine mount thats behind the engine on a 1997 2L 8V gti I have changed the front and gear box side mounts no problems. The haynes manual is as much use a chocolate fire guard!! Do you have to work from underneth or can you remove air intake and work from above? Can the engine be supported by a jack from underneath whilst doing this?
  2. Talking Re: Golf mk 3 rear left engine mount change
    Feb 2007
    Has anyone on here done this?
  3. Re: Golf mk 3 rear left engine mount change
    133 Post(s)
    1988 Post(s)
    Above and below, great fun to get at, not!
  4. Re: Golf mk 3 rear left engine mount change
    Feb 2007
    Thought as much. Done the other two and drive has improved 85% but still knocking ( Reduced noise) When driving so looks like another night hugging the engine and donating knuckles in the process!
    Thanks for the reply
  5. Re: Golf mk 3 rear left engine mount change
    Dec 2007
    Inverness
    hey mate, slow reply lol youve probably done the job by now but yes, you should be able to support the engine under the sump, and be able to reach the mounting from above. i think its just a big bolt straight through from the top, similar to the gearbox mounting on the n/s.
    hope this helped
    N reg mk3 golf 1598cc
    Rolling stones anniversary trim
    dragon green
    Favourite mod - vanilla magic tree
  6. Re: Golf mk 3 rear left engine mount change
    Feb 2007
    Still building upto it! Hope to start one night this week will post once I've done it.
  7. Re: Golf mk 3 rear left engine mount change
    Feb 2007
    Changed the engine mount was a tough job but is ok once the car is up in the air. Whilst jacking the car up noticed that the passengers drive shaft has a clicking when turned at the joint where you can split it the Gearbox so looks to be a drive shaft after all at least all engine mounts are new and ruled out.
  1. rear top mount
    By mikeya4 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 16-03-2008, 06:09 PM
  2. Rear left light warning
    By nutter1980 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 03-03-2008, 08:59 PM
  3. mk 4 golf engine mount
    By scammel in forum Golf MK4 - 1999 - 2004
    Last Post: 22-10-2007, 09:38 PM
  4. knocking at the left rear
    By NIgolf in forum Passat - Archive Topics
    Last Post: 26-03-2007, 10:09 AM
  5. golf IV - rear brake change
    By ned in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 26-10-2006, 10:13 PM
