Thread: A3 BKD TDI 140 Idle shudder/judder?
  1. Cool A3 BKD TDI 140 Idle shudder/judder?
    VAGster Guest
    Hi all im a new member and this is my first post.
    Had an A3 Sport BKD 140 TDI about a month and trying to resolve the dreaded idle judder! 53 plate 87K. Very annoying as I love the car!
    Seen many posts on this but none solving the problem.
    Dont believe its the DMF, as my problem is when its up to temp(perfect when cold) and clutch up/down makes no difference also no clutch judder. Anyone know if below technical bulletin ECU update is relavent/works from Audi??(Taken from Elsawin for VW Golf V TDI)
    Would try to up idle slightly with Vagcom but cant find a guide to do this on mine that works? Anyone done it on this BKD engine?
    Already tried
    Disconnecting MAF
    Disconnecting fuel temp sender
    Replacing injector wiring loom under rocker cover.
    checked coolant temp sensor (warms up gradually to 80 -90C)
    scanned for faults (nothing on engine just instrument cluster prob)
    Cambelt just done was same before.
    None have made any difference.
    Any help/advice appreciated. Thanks!
    Technical solution
    Transaction No.: 2005869/9
    Erratic idle speed in warm condition
    Release date: 23-Dec-2005
    Problem description
    Erratic idle speed with hot engine.
    Cause
    Adjustment in the engine control unit.
    Production solution
    Optimised software:
  2. Re: A3 BKD TDI 140 Idle shudder/judder?
    We have same prob apart from ours actually cuts out usually when engine is cold. Ours is DSG so more difficult to control
    did you get to bottom of this?
    the only thing thats improved ours is increased idle speed.
    whats yours set at?
    Ian
  3. Re: A3 BKD TDI 140 Idle shudder/judder?
    Aug 2009
    warwickshire
    how did u djust your idle speed ?
    Quote Originally Posted by sprout99 View Post
    whats yours set at?
    Ian
  4. Re: A3 BKD TDI 140 Idle shudder/judder?
    Sep 2009
    hull
    i have the same problem on my a4 1.9 tdi only idles rough when warmed up changed the coolant temp sensor..now i might try the coolant temp sender.
  5. Re: A3 BKD TDI 140 Idle shudder/judder?
    Jul 2009
    Somerset UK
    any news guys... i too now have the same issue.... my cars starting to have a list of issues!!
  6. Re: A3 BKD TDI 140 Idle shudder/judder?
    Sep 2009
    hull
    well tried the new coolant temp sender and its still the same
    so now looking towards the fuel pump side of things now..although the car seems to run slightly better its still very lumpy at tick over.
    I will keep you posted if i get any further.
  1. Ive Fixed My A4 Tdi Judder At Last Please Read If You Have A Judder
    By justin@justinwa in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 23-11-2009, 08:32 PM
  2. Jetta 2.0 Tdi SE 13K '06 Judder at idle
    By phildulson in forum Jetta MK3 - 2005 - 2013
    Last Post: 20-04-2008, 06:10 AM
  3. VW Jetta 1.6 Petrol - Idle - Judder - Brand New
    By procus in forum Jetta MK3 - 2005 - 2013
    Last Post: 25-03-2008, 11:09 PM
  4. a3 1.8T sport (x reg) Occasional Judder/Erratic Idle/EMS light
    By tusken in forum Audi A3 - Archive Topics
    Last Post: 04-01-2008, 10:17 PM
  5. A4 Avant '99 Shudder through the car at 60-65
    By radiojuan in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 30-05-2007, 06:44 PM
