Thread: wiper arm removal
  1. Wiper Arm Removal
    Nov 2006
    Okay, finished swearing at my car for the time being and time to get some advice! I can't remove the o/s wiper arm. Have got the n/s one off with a puller, but there's no space for the puller on the o/s one (without removing the bonnet!), nor any space to get underneath the spline with a prising tool (this could damage the windscreen cowl, I reckon). Have WD40'd and twisted and tugged the arm, but no joy.
    Am removing the wiper arms in order to be able to remove the windscreen cowl in order to be able to remove the battery in order to get to the (blocked) drain holes beneath in order to prevent the rear o/s footwell from turning into a swimming pool!
    Car is 130tdi sport wagon. Battery is big, so won't come out any other way, or so I gather from other threads.
    Thanks.
  2. Re: Wiper Arm Removal
    Ashbourne Derbyshire UK
    Mine is a 130TDi sport wagon / Estate also & you can remove battery with the cowel in place..... I did it 2 weeks ago . The plastic will bend a long way B4 it will break. One of my drain holes was compleatly blocked, other one 1/2 blocked ..... just in time b4 a swimming pool. If you take your time , unclip all the pipes at front of the chamber the battery will just squeeze through at an angle. Good luck !
    Once owned 98 1.8 ADR SE non turbo passat estate(The Mrs wrote it off)
    Now own 03 TDI 130 Sport 6 Speed passat estate
  3. Re: wiper arm removal
    I used a balljoint splitter on my wiper arms, it worked a treat, I tried to remove the cowl but it would not budge so I did the job with it in place. If you tilt the battery to 30 degrees and lift it out it will come but it is very heavy and a long way away from you.
  4. Re: Wiper Arm Removal
    Sep 2007
    You can also just turn the wipers on. Wait until they are at the top of their travel and then switch the ignition off. This way the cowl will actually have a bit more leeway to move. Worked for me.
  5. Re: wiper arm removal
    Nov 2006
    Good stuff, thanks very much guys. I can thoroughly recommend following this link http://www.weirdlittlebiscuit.com/passat/leak for some clear advice and excellent photos should anyone else be tackling this issue. Got my battery out in the end with cowl in place, but with the big battery it's NOT EASY (putting it back is even worse!). If you can get the cowl off, do it. Drain holes were completely blocked with gunge - quite disgusting!
  6. Re: wiper arm removal
    Sep 2007
    North Wales
    Just pull this loom off as described in the link above and there is plenty of room.
    Steve. 2002 (52) Passat 1.9 TDi 130bhp (AWX)
  1. Rear wiper removal.
    By Coastie in forum 80 - 90
    Last Post: 25-02-2008, 04:55 PM
  2. Passat Wiper Arm removal
    By ashab02 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-01-2008, 08:08 PM
  3. Audi A4 wiper arms - Aero wiper arms?
    By paul46 in forum Archive posts
    Last Post: 08-09-2007, 05:47 PM
  4. A4 wiper arm removal
    By paul46 in forum Audi A4 - Archive Topics
    Last Post: 02-04-2007, 11:59 PM
  5. 2002 A4 Wiper Arm removal
    By rockyarsenal in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 23-12-2006, 01:08 AM
