Thread: Door lock won't release door
  1. Door lock won't release door
    Hello,
    Can anyone advise if it is possible to release the deadlock on my Mk4 Golf as the door will not open. The central locking function is working as all four doors unlock but the drivers door will not open if either the internal lever or external handle are pulled. If I can get the door opened I can sort out whatever is causing this situation but I don't know how I can release the deadlock with the door closed? Any advise appreciated.
  2. Cool Re: Door lock won't release door
    leeds
    Quote Originally Posted by Anarra View Post
    Hello,
    Hi Anarra,
    I had a similar problem with my passenger door.
    I sprayed some WD40 between the door frame and the door (inside the car).
    Using the WD40 plastic stray, I sprayed as close to the lock as possible, between the door frame and door and I manipulated the door handles inside and outside until it opened.
  3. Re: Door lock won't release door
    Hi Chad,
    thanks for your response, I didn't think to spray in some lubricant, I'll give it a go!
    Rgds
  1. door lock help please
    By bigtow in forum Golf MK4 - 1999 - 2004
    Last Post: 29-03-2008, 09:39 PM
  2. Door lock
    By desparate22 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-01-2008, 03:26 PM
  3. GT Tdi lock n door cards help !!
    By quaidpinder in forum Chat - Anything with wheels
    Last Post: 11-09-2007, 09:55 PM
  4. Bouncing door lock
    By Gismo in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-09-2007, 10:24 AM
  5. HOT door lock
    By megablade in forum Audi A4 - Archive Topics
    Last Post: 19-06-2006, 02:52 PM
