Thread: 80 ADA Decat pipe
  1. 80 ADA Decat pipe
    murphyv310 Guest
    Hi.
    I am looking to fit a De_cat pipe on my 80 1.6 ADA engine as the cat is blowing and at the moment will fit a de-cat pipe rather than the expence of a new cat. Any ideas as to where I can obtain one.
    Trevor
  2. Re: 80 ADA Decat pipe
    Jul 2007
    somerset
    8 Post(s)
    I had the same problem on my 1990 Audi 80 2.0 litre sport, i got the part numbers from an exhaust catalogue (friendly tyre and exhaust place) and we found that some audis that don't have a cat have a straight bit of pipe instead. We just matched up the part numbers on my exhaust on the bits between the cat and searched in the catalogue till we found a non cat version with the same part numbers between the cat, then ordered the bit that replaces the cat. He had to weld a bit on where the lambda probe goes in or something and job done. You could make your own by using the original flange bits and welding a piece of pipe between at the correct length. Most people seem to want £100 up for a specialist de-cat pipe, its up to you if you want to spend that on your car.
  1. decat for 2ltr sport
    By borat20 in forum Bora - 1998 - 2005
    Last Post: 28-03-2008, 09:52 PM
  2. fittng milltek decat pipe to original downpipe
    By mystic 8v in forum Golf MK3 - 1993 - 1999
    Last Post: 17-03-2008, 07:55 PM
  3. Diesel decat
    By Dave Avant in forum Audi A4 - Archive Topics
    Last Post: 17-10-2007, 06:45 PM
  4. 3.0 V6 decat
    By inertia in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-09-2007, 08:51 AM
  5. oil in pipe tp the egr?
    By Vdubba in forum Archive posts
    Last Post: 23-04-2007, 09:22 PM
