Thread: Oil - safe to rely on the warning light?
Results 1 to 10 of 20
  1. Oil - safe to rely on the warning light?
    orangezorki Guest
    Hello all,
    I've had my 170 TDi over a month now, so decided to have a look under the bonnet! Firstly, I was very impressed with how the bonnet held itself up, but then not so impressed with the dipstick. I know it's been talked about before, but what (ahem) dipstick designed this part. Firstly, the black oil is almost impossible to read on the black stick, and then there are so many bobbles on it, that without a dealer showing me, I read the wrong bit and thought that the engine was haemorraging oil!
    Looking again yesterday, I think I'm alright for oil at the moment, but still not confident I can read the dipstick properly. Just to be sure, I've bought 1L of the correct oil (VW 507 00), and put it in the boot.
    So, my question is - am I safe to wait for the oil light to come on - if it ever does - then immediately pour a litre in?
    David.
    (Thanks for any replies)
  2. Re: Oil - safe to rely on the warning light?
    Sep 2007
    Quote Originally Posted by orangezorki View Post
    ...am I safe to wait for the oil light to come on - if it ever does - then immediately pour a litre in?
    Well, that's what I do. The oil consumption on my 140 is so abysmal (2600 miles/litre!) that it's the only way I can keep a proper check on it, given that the dipstick is almost impossible to read. Whether running it this low is a good idea is another matter of course.
    And, yes, I carry a litre container in the car. I have discovered one of the little cubby holes in the boot (of the estate) is just the right size!
    Passat B6 2.0 TDI 140 Estate 2007
  3. Re: Oil - safe to rely on the warning light?
    David.
    Well I suspect that the idea of the light is to warn you before the level gets low enough to cause any engine damage, so you should be OK, but of course that presupposes that your warning light is working properly, so perhaps it's best not to rely on it totally.
    Although it is difficult to read the dipstick accurately, on the other hand you can get an idea of how the oil level is reducing, so to that extent you can top it up before the warning light comes on.
    If I remember correctly when the oil is on the top bulbous bit you shouldn't put any in, but when it's in the slim middle bit - which is the easiest bit to read - you can put some in if you want, but it's not critical. When it gets down to the lower bulbous bit then you must top it up. The problem for me here is that this is the level where it gets difficult to read, so it's easy to leave it because you can't accurately read it, and before you know it the warning light is on.
    If you have plenty of dosh I would fill it when it's halfway down and easy to read, but since I'm not awash with money I tend to leave it a bit longer, and don't want to stick a tenner's worth of oil in when the service light might come on any day.
    Coincidentally, my low oil light came on today, and further coincidentally my the service indicator came on at the same time as well. So I'll probably just stick in a quarter litre (I normally put in a half litre) and hope that lasts the thousand miles or so till the service.
    06 Passat 2.0 TDi 140 SE Estate, Reflex Silver, 125,000 miles
  4. Re: Oil - safe to rely on the warning light?
    Scunthorpe
    I'm pretty bad and I do the same - My oil consumption is pretty good.
    Question though - when the oil's at the lower marker - is one litre enough?
  5. Re: Oil - safe to rely on the warning light?
    Dec 2007
    Dudley, West Midlands
    44 Post(s)
    Hi all, one point you may have missed is the oil light is oil pressure not oil level, so if the oil light is coming on the oil pressure is low, so you are running the risk of early engine failure due to wear.
    Regards Dean Warren. VCDS owner/user
    A6 C7 3.0 BiTDi Quattro Avant 2012 S-Line Tech pack tour Pack ACC Blind spot folding mirrors Sold
    S6 C8 3.0 TDI Quattro Avant 2021 360 Camera Bose Extended leather.
  6. Re: Oil - safe to rely on the warning light?
    Apr 2007
    France
    12 Post(s)
    Quote Originally Posted by james_tiger_woo View Post
    Without going and getting my handbook, don't VW say to add one litre at that point? Apologies if I'm wrong.
    I find that the best way to read the useless dipstick is to wipe it, return it, withdraw it carefully, and press it on a folded-up piece of kitchen roll. The impression it leaves should make it just that little bit easier to read....
    Edit: the only time I remember to check my oil is when one of these threads comes up.
  7. Re: Oil - safe to rely on the warning light?
    Scunthorpe
    Quote Originally Posted by Quatrelle View Post
    **slinks out to check his oil**
  8. Re: Oil - safe to rely on the warning light?
    I think you're right - isn't it one litre from the bottom bulbous part and half a litre from the middle part?
    That seems to be the idea of the dipstick - to make it easier to know when to put oil in and how much to put in. Of course, the problem is that few seem to read the handbook to know this, and no one can read the dipstick properly anyway
  9. Re: Oil - safe to rely on the warning light?
    Quote Originally Posted by dean warren View Post
    The Passat has both oil pressure and level warning lights.
    The oil level warning light is orange and a message is displayed telling you to check your oil level.
    The pressure warning light is the usual red. Don't know how low the oil level has to go before it's displayed, but I suspect it also provides a displayed warning which is a good deal more urgent than the "check your oil level" one
  10. Re: Oil - safe to rely on the warning light?
    Just to clarify what I said earlier, in case anyone hasn't read the manual.
    The slimmest part of the dipstick is where the oil should normally be, and you can top up with up to half a litre.
    There's a slightly thicker bit below that, and at this point you can top up with up to a litre.
    Above the slimmest bit is a slightly thicker bit, and if the oil is at this level then you shouldn't add any more.
    The bulbous bits I referred to earlier are in fact above and below the slightly thicker bits, thus you shouldn't be in these areas at all - I think the oil level warning light comes on when the level is moving from the slightly thicker lower bit to the lower bulbous bit.
    Of course, that's the SP on my model; others may be different.
    Might have been easier if they'd just supplied a standard dipstick with marks for the maximum and minimum levels
  1. oil warning light!!
    By gasandair in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 20-04-2008, 12:50 AM
  2. Air bag warning light, Brake warning light
    By michaelboyd49 in forum 80 - 90
    Last Post: 30-11-2007, 09:50 PM
  3. Exhaust/Engine Emission Warning Light Constant Orange & EPC Light intermittent!
    By karl578 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 07-06-2007, 10:59 PM
  4. DIS Brake Fluid Warning with ABS warning light
    By radar1022 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 03-04-2007, 10:42 AM
  5. Brake fluid warning light with ABS light
    Last Post: 02-04-2007, 03:28 PM
