Thread: oil filter, oil pump. turbo or engine- You decide!!
  1. Question oil filter, oil pump. turbo or engine- You decide!!
    cornwall
    hi
    great forum, great advice
    my gt tdi150 has just brought up the dreaded- 'Stop- oil pressure' red dash warning sign.
    my partner was driving and has driven approx half a mile to get it back home with it on.
    im worried.
    levels are ok, no milky deposits but i know i am due an oil change/service.
    simple question. whats the problem?
    oil filter sludged up and dead
    oil pump dead
    turbo dead
    or engine......
    im getting rac to do a check tomorrow- hopefully they will advise
    any help would be appereciated
    thanks
    jonny
  2. Re: oil filter, oil pump. turbo or engine- You decide!!
    kimandsally Guest
    Dip the oil probably just a bit low, if so just top it up and see if it cures it.
    My first impression you "should" be OK.
  3. Re: oil filter, oil pump. turbo or engine- You decide!!
    cornwall
    the oil level has been good for last six months. its right in the middle.
    the rac man thinks the oil filter is best place to start and obviously a change and probably a flush.
    im dropping it off at Phil Davies Vw specialist in Plymouth tomorrow
    he'll fix it im sure
    i just hope its not mechanical damage eg engine
    il wait and see....
    cheers
    jonny
  4. Re: oil filter, oil pump. turbo or engine- You decide!!
    kimandsally Guest
    Yes if the oil filter is blocked it "could" do that although most have a valve to stop it happening.
    I would drive real cauciously until it's found what is wrong, I can tell you that if there is no oil pressure it will destroy the main bearings and big ends very quickly, I cannot stress enough take it easy until the problem is found.
  1. turbo or fuel pump?
    By barnsleyman in forum Chat - Anything with wheels
    Last Post: 15-03-2008, 12:52 AM
  2. Engine oil filter cap
    By Gg22 in forum Chat - Anything with wheels
    Last Post: 02-12-2007, 08:35 PM
  3. Please help decide! mrk 4 or 5?
    By The Bishmeister in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 27-09-2007, 07:28 PM
  4. 2.0 fsi 2.0 tdi cant decide
    By sbt in forum Audi A3 - Archive Topics
    Last Post: 19-08-2007, 06:19 PM
  5. HELP - Where is the oil filter on 115 PD engine?
    By wid77 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 28-02-2007, 10:02 AM
