Thread: Oil on inlet manifold mk4 gt tdi 110
  1. Oil on inlet manifold mk4 gt tdi 110
    I have replaced my glow plugs today after having a problem with starting since i bought my golf.It started fine today after replacing the plugs,anyway as i took off the engine cover i noticed there was black soot/oil on the inlet manifold and above is a pipe which looks rather oily.I also removed the pipr from the EGR valve and it is gunged up inside,nice!
    Just wondering if the black soot/oil deposit on the inlet manifold is anything to worry about?The EGR needs to be cleaned along with he inlet manifold but that'll be another job
    Any ideas on what the leak means and could it affect performance?
  2. Re: Oil on inlet manifold mk4 gt tdi 110
    Hi If it is not excessive then it is normal
  3. Re: Oil on inlet manifold mk4 gt tdi 110
    Nope not excessive,thank god!
  1. 1.8 8v inlet manifold getting hot
    By oli325 in forum Golf MK1 - 1974 -1984
    Last Post: 28-03-2008, 07:37 PM
  2. Inlet Air Temperature Sensor
    By djbcatlett in forum Touareg
    Last Post: 04-02-2008, 05:12 PM
  3. passat 1.9tdi, oil in air inlet
    By southamptonadi in forum Archive posts
    Last Post: 17-11-2007, 05:13 PM
  4. Oil and sooty inlet manifold
    By happysnappy in forum Passat - B5 Forum - 1997 -2005
    Last Post: 27-10-2007, 01:17 PM
  5. inlet air temp sensor
    By jim80 in forum 80 - 90
    Last Post: 26-11-2006, 05:17 PM
