Thread: A6 Turbo Needed for a 1.9Tdi PD130 2003 53 reg,
  1. A6 Turbo Needed for a 1.9Tdi PD130 2003 53 reg,
    It seems that I have blown the turbo on my A6 1.9tdi PD130, its a 2003 53 reg, I am looking for a supplier that is cheaper than Audi who are quoting £1200, French, Swedish and German £800.00.
    The turbo also drained my Engine of oil, but no distance was travelled, but this apparently tells you the type of turbo.
    I will get the serial numbers off the turbo as soon as it has been removed.
    Any suggestions would be greatly received and appreciated.
    Craig
    07767 432224
  2. Re: A6 Turbo Needed for a 1.9Tdi PD130 2003 53 reg,
    Jun 2007
    "The turbo also drained my Engine of oil, but no distance was travelled, but this apparently tells you the type of turbo."
    Explain !! Was the engine running when it emptied the engine. How smoke was/is it. Regards Peter
  3. Re: A6 Turbo Needed for a 1.9Tdi PD130 2003 53 reg,
    Yes the engine was running, accelerating down a dual carriageway, loss of power, lots of white smoke coming out of the exhaust, I had to drive about 600 yds to get off the dual carriageway, but I was travelling at about 15mph low revs.
    The engine still starts and drives, but I had to be AA'd back to my local garage who are to investigate tomorrow, but I know they will probably say 'new turbo'.
  4. Re: A6 Turbo Needed for a 1.9Tdi PD130 2003 53 reg,
    Apr 2007
    Lancashire
    Any of the longitudinal engined GT1749VA turbo's should fit ok (AWX).
    As will the virtually identical 2.0ltr 16v 140bhp common rail units.
    A4, A6, Passat etc.
  5. Re: A6 Turbo Needed for a 1.9Tdi PD130 2003 53 reg,
    May 2007
    knee deep in clunge
    14 Post(s)
    ive got two if your near st helens then £50
    vag diagnostics, retrofits and general repairs
  6. Re: A6 Turbo Needed for a 1.9Tdi PD130 2003 53 reg,
    'ive got two if your near st helens then £50'
    A8 Tech, thanks for the message, can you tell me if these are definitely the correct one for this car, are they recons, secondhand, and do you have a reference number on them, I will get the garage to check the numbers on mine and see if they are the same.
    Can you also send me a text to 07767 432224 and I will call you regarding.
    Please note that I will be away for 12 days, so I can come and collect upon my return.
    Craig
  1. A6 1.9tdi 2003 TCM and jerking
    By paresh in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 12-04-2008, 09:44 PM
  2. Help! Cold start problem 1.9TDi (PD130)
    By sinso in forum Golf MK4 - 1999 - 2004
    Last Post: 08-12-2007, 06:41 PM
  3. A3 1.9TDi PD130 servicing intervals
    By michaelab in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 09-06-2007, 04:12 PM
  4. Audi A4 1.9TDI 100bhp TURBO CHARGER NEEDED!!!
    By cha3 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 07-06-2007, 11:41 PM
  5. Weird noise from engine (TDi PD130 2003)
    By Neil R in forum Passat - Archive Topics
    Last Post: 21-10-2006, 12:00 PM
