Thread: Oil filter tool?
  1. Oil filter tool?
    Jul 2006
    Anyone kn ow what the part no. is for the tool to remove the oil filter cap?
    Sensible answers only please!
    Dec 2006
    i know you have said "Sensible answers only"
    however i use a big pair of mole grips to remove mine (as it does not matter if you damage it when its coming off... )
    and then fit it by hand and tighten it by hand..
    (i have a A4 and the filter is large so you can get a good grip when putting back on!)
    However... buy yourself one of these... this items pretty cheap at the moment on ebay..
    http://cgi.ebay.co.uk/PROFESSIONAL-O...QQcmdZViewItem
    RickT
    Jul 2006
    Quote Originally Posted by RickT View Post
    RickT
    Cheers for that, I too have used this technique as well as punching a screw driver through the filter unit, gets a bit messy, thing is mine is for a TDI deisel engine and its a paper type filter which is housed in a cast alluminium unit with a nylon/plastic cap. I've tried my vice like grip but it an't wot it used to be, I've noted that around the outer part it has a lot of flat segments similar to what's on some of the other can like filter units (the normal ones) if you know what I mean.
    Thanks for your reply anyway, nice to know there is someone out there.
    WT
    Have you had a look on the net?
    Here for example: http://www.toolspot.co.uk/category/filter-wrenches
    or here: http://www.justoffbase.co.uk/Tool-Shop/Oil-Filter-Tools
    I have used a big pair of swan neck pliers or a strap wrench if space is limited.
    Regards Boardboy
    Jul 2006
    Thanks for that Boardboy, I'll give it a go.
    Oct 2005
    Chester, U.K
    I've seen them in *********.
  1. Diagnostic Tool.
    By jasear in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-04-2007, 11:42 PM
  2. Viewing alloys on your car before you buy? Online tool?
    By woza in forum Golf MK4 - 1999 - 2004
    Last Post: 19-03-2007, 04:14 PM
  3. PD130 Crankshaft locking tool
    By vincentbob in forum Passat - Archive Topics
    Last Post: 18-03-2007, 08:44 PM
  4. V5 Cam lock tool
    By colifeashots in forum Passat - Archive Topics
    Last Post: 10-01-2007, 08:14 PM
  5. Oil filter tool for Mk5 TDI 103PS
    By NRG in forum Golf MK5 - 2004 - 2009
    Last Post: 24-08-2006, 10:41 PM
