Thread: viscous fan hub
  1. viscous fan hub
    could do with some advice please Just got my 1999 audi A4 1.6 back from the garage and i have been informed that my viscous fan hub is faulty is this easily replaced will this once fixed stop my car from stalling when first started
    thanks
  2. Re: viscous fan hub
    Mar 2008
    ah i think i know what this is and should nto be do bad
    your fan which cools your engine is attached directly to the engine
    via a pully
    now because the amount of energy needed to spin engine it could when cold i propose re stall the engine
    so what you do is attach the fan via vicous coupling which does not let the fan spin stright away and there is always a bit of a lag and thats whats the pully is for
    anyway
    you take off serp belt
    remove the fan and pully replace
    and away you go
    now this is from memory of another engine that is the same kinda thing
  3. Re: viscous fan hub
    Mar 2007
    i very much doubt this is the cause of your stalls.
    best get it fixed anyhow, the fan is a bit of a pain to get out on my 1.8 as there is so little clearance between it and the engine and the radiator. there may be a little more room in your 1.6 though.
    think about how much resistance is put on the engine from all of its own heavy components, and then the flywheel, gearbox shafts, power steering pumps, coolant and oil pumps, alternator etc etc. the fan weighs peanuts in comparison and is unlikely to cause the stalling.
    the point of the viscous unit is that it only locks up (and turns the fan) when the engine gets warm. this way energy is not wasted cooling a cold engine thats just been started.
  1. Viscous coupling fan
    By daisytaff1 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 09-03-2008, 11:12 AM
  2. Viscous fan
    By LtsMan in forum The Commercial Range
    Last Post: 29-01-2008, 06:24 PM
  3. Audi A4 Viscous Fan Coupling
    By BrendanMC in forum Audi A4 - Archive Topics
    Last Post: 11-11-2007, 11:00 PM
  4. Viscous fan- sound on start up.
    By Mike McKinstry in forum Passat - B5 Forum - 1997 -2005
    Last Post: 15-07-2007, 08:34 PM
  5. viscous fan
    By a4fooltdi in forum Audi A4 - Archive Topics
    Last Post: 30-05-2007, 10:29 PM
