Thread: L reg Avant 1.9tdi front subframe bushes......
Results 1 to 10 of 11
  1. L reg Avant 1.9tdi front subframe bushes......
    Dec 2006
    Kent
    .......anyone replaced their's?
    It's the rear mount's on the front subframe apparently. It's just failed the mot on 'em.
    Need to now if it's a home or garage jobby.
    Cheers.
    Older, wiser and cheaper to insure
  2. Re: L reg Avant 1.9tdi front subframe bushes......
    Dec 2007
    8 Post(s)
    If its the same as saloon it is possible as a diy job although it will take time
    I done this job on a saloon while I had gearbox and suspensions removed
    I removed the sub frame to do same
    If gearbox and suspension are in place they would need to be supported as
    they are attached to subframe
  3. Re: L reg Avant 1.9tdi front subframe bushes......
    Aug 2008
    did you have any joy with the subframe bushes as I am having a mare trying to fit mine! Help?
  4. Re: L reg Avant 1.9tdi front subframe bushes......
    Dec 2006
    Kent
    I removed the subframe, and found the bushes to be ok.
    I took it to the guy who failed it on the mot, and he admitted they were fine, so i put it back.
    It did'nt look like a nice job either way.
    Sorry i can't be more helpful.
    Good luck, Daz.
  5. Re: L reg Avant 1.9tdi front subframe bushes......
    Dec 2007
    8 Post(s)
    Quote Originally Posted by chanleman View Post
    I can not remember precisely how I changed mine but it
    would have been with two suitably sized metal tubes with a
    long bolt and flat washers to pull new bushes into place
    I think the rubber part had to be lubricated and teased through
  6. Re: L reg Avant 1.9tdi front subframe bushes......
    Pembrokeshire
    22 Post(s)
    the easiest way is once the subframe is removed, take it to a garage that has a press, hand over some folding beer tokens, and watch as they are pressed out, and new ones pressed in. alternatively, remove the old ones by drilling out the rubber so you can knock out the centre part, then carefully hacksaw the outer. this will relieve the tension so you can easily remove it. then put back together using alloy solid mounts. these fit over and under where the bushes go, and dont require pressing in.
    incidentally, i have known these to feel fine with the subframe removed, but to allow the subframe to move once in place, due to the rubber being soft.
  7. Re: L reg Avant 1.9tdi front subframe bushes......
    Aug 2008
    cheers guys! My problem = GSF supplied wrong ones. My local car place got some and with the help of said round tubes and a long jaw vice...the remaining two stubborn ones went it!
  8. Re: L reg Avant 1.9tdi front subframe bushes......
    Sep 2007
    The best way is to burn the old ones then they just pop out and then buy poly one's as they fit in easy if you have the right tool like below
    http://cgi.ebay.co.uk/BRITOOL-VOID-B...1%7C240%3A1318
    By the way i have done about 20 sets of subframes bushes
    cheers RAJ
  9. Re: L reg Avant 1.9tdi front subframe bushes......
    Sep 2007
    And just one more thing i have had subframes fitted with automatic bushes on the rear part of the subframe this is quite common there is a massive difference from auto and manual bushes the manual one's will just burst in the middle
    cheers Raj
  10. Re: L reg Avant 1.9tdi front subframe bushes......
    Sep 2010
    Bridgend Wales
    Hi, I know this is an old thread, but it looks as though I may have to do this job on my A4. I am having trouble sourcing the bushes, and can't even find a part number. Please can anyone tell me where to get some, or the part numbers at least.
    baltiboys2 mentions poly-bush mounts. Where could I get these, and do they have any adverse affects on ride/handling?
    Thanks.
  1. Front Anti Roll bar Bushes - How much??
    By CPD in forum Golf MK4 - 1999 - 2004
    Last Post: 09-04-2008, 06:05 PM
  2. A4 Avant 1.9tdi AHU
    By adele562 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 28-02-2008, 10:37 PM
  3. Front Suspension Bushes
    By Radders in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 19-01-2008, 04:52 PM
  4. 1.9TDi SE Front Bushings
    By diesel-a4 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 04-01-2008, 02:08 PM
  5. front suspension bushes
    By ashfield in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 29-12-2006, 11:45 AM
