Thread: can anyone point me in the right direction??????
Results 1 to 10 of 18
  1. Lightbulb can anyone point me in the right direction??????
    hi there to all.i've just recently bought an audi a4 avant tdi se,2003.
    i'm looking for some information if any1 can help me please!!!!!
    the help i'm looking for is.......on all four doors and the tailgate there are lights that should come on when the doors or tailgate are open,mine arent!!!! Has any1 got any ideas as 2 why and could you point me in the right direction to put this right(AS THIS IS DOING MY HEAD IN!!!!)
    very kind regards,darren.
  2. Re: can anyone point me in the right direction??????
    Manchester, UK
    are you sure your audi has these lights, because not all of them do.. if it does then maybe its a fuse?
  3. Re: can anyone point me in the right direction??????
    Dec 2006
    As all four dont work it sounds like a fuse issue..
    The SE did come with door lights..
    Rick
  4. Re: can anyone point me in the right direction??????
    Lancashire
    My 54 plate SE Avant has what looks like lights on all the doors but only the boot one works
    54 Audi A4 Avant 1.9TDi 130 SE 6-speed, RNS-E, rear parking sensors, bluetooth
  5. Re: can anyone point me in the right direction??????
    Dec 2007
    Aberdeenshire, Scotland.
    I have the exact same car- 2003 A4 Avant tdi SE- all my door lights plus boot light work ok.
    Sounds like a fuse or relay problem.....
  6. Re: can anyone point me in the right direction??????
    thomswalwell Guest
    any one know what fuse and where it is?
    i was changing a bulb in my drivers door, and somehow it shorted and im not sure what fuse or where it is to replace it.
    i looked in the fuse panel, but all i could see was numbers 22 and 23, drivers door and passengers door, but doesnt say what the fuse is for exactly.
    all the other doors work, but not the drivers door. that is what makes me think there is a fuse for each door. number 24 fuse is for central electrics unit for conveinience unit but i couldnt get what that was for.
    thanks
  7. Re: can anyone point me in the right direction??????
    thomswalwell Guest
    anyone?
  8. Re: can anyone point me in the right direction??????
    thomswalwell Guest
    UPDATE:
    i took my car into audi today, but they didn't really have any idea. they wanted £114 to do diagnostics on the car, to which i said no. ill probably do some research online about it and then if I'm not successful, then ill take it to my local auto electrician to see if he can fix it. I've used him in the past and been happy with the results. (for a different car)
    anyone had any ideas? they said it could be due to the convenience unit, or a faulty wire between door and car, but i havent checked that as yet. since it basically shorted when i removed the bulb, i expected it to be a fuse. not so simple it seems..... im really thinking about removing the door trim, even just to have a check for faulty wiring, since my tweeters in the door are also crackling, and the problem with water in the battery compartment.
    Thom
  9. Re: can anyone point me in the right direction??????
    May 2008
    There wont be a fuse for each door light.
    Does your interior light work?
    Are you 100% sure your car has these lights? Spec's vary wildly over the years, many cars just had red reflectors in the doors. Take them out to make sure they contain properly wired bulbs.
    Failing that, go through the fusebox and check each one is OK. Its not always clear or obvious which fuses feed exactly which components.
    Its a fairly common problem for wiring to break down in the rubber boots that go between the door and the body of the car.
  10. Re: can anyone point me in the right direction??????
    thomswalwell Guest
    hi
    thanks for the reply.
    yes i definitely have the lights. all other doors have them and are turned on when the door opens, as well as footwell lights. the interior lights all work ok, and on opening the drivers door, the interior front and back lights go on, the drivers footwell light, but the 2 on the door, the red light at the back and white light on the bottom (puddle light?) do not illuminate. i was changing a bulb over, and used a metal screwdriver and must have shorted them out somehow. stupid mistake i know, but i cant seem to fix it. i tried replacing the bulbs but to no avail.
    i was a bit confused to say the least on trying to find a fuse. if these door courtesy lights are in fact part of the convenience unit, then i dont know why the drivers door lights no longer work but the other doors are ok.
    the tail light on the boot red one side white the other doesnt work, but thats because i think i have a blown bulb. i havent tried that as yet, but i assume thats part of the same wiring circuit.
  1. 1996 Polo - fuel filter direction
    By dukla2000 in forum Polo - Derby - Lupo - Fox
    Last Post: 13-10-2008, 10:31 PM
  2. Rear Centre Seat belt - 2 point to 3 point?
    By Rob Wollaston in forum Chat - Anything with wheels
    Last Post: 14-02-2008, 05:10 PM
  3. Scanning Point
    By ross_Darroch in forum 80 - 90
    Last Post: 13-02-2008, 07:25 PM
  4. Direction Indicator bulb replacement
    By Malcolm Winter in forum Golf MK4 - 1999 - 2004
    Last Post: 23-12-2007, 04:36 PM
  5. Tribu Concept Previews Seat’s Future Design Direction
    Last Post: 12-09-2007, 08:54 PM
