Thread: stuttering A4.. ? New to Audi. Just bought it !!
Results 1 to 10 of 12
  1. stuttering A4.. ? New to Audi. Just bought it !!
    I am a new Audi owner, just bought what looked like a nice late 1999 A4 1.8 SE automatic. I drove it home 35 miles on the motorway and it drove nice...no problems. I go to start it up a bit later and it coughs and splutters and pops like mad.
    So I leave it a while and then try again, it runs rough as a bag of farts but after a short while it seems to pick up power and drives quite nice. then I put my foot down to 65-70 mph and it starts spluttering again.
    This morning I try it again and its WORSE. I can't even drive out my driveway. Coughing and spluttering ...real rough....sounds bad.
    Please can anyone give me an idea of the problem ?? and cost ??
    My guess is anything from these... but I know jack **** about cars so ??
    Coilpack ??
    Mass air flow meter ??
    Cat problems ??
    Injection problem ??
    Any advice would be appreciated. Its a shame my first post on the Audi forum is one of problems and woe. I have only ever driven Japanese cars for the last 20 odd years (mostly Toyota) and never had any reliability problems. Just fancied a change so sold my Avensis and bought this dog...doh
    thanks
    Regards
    Dave
  2. Re: stuttering A4.. ? New to Audi. Just bought it !!
    The coils are an easy change, and would be my first thing to try. Just buy one new one and swap them one by one until you find the faulty one. Check your spark plugs while you are there, make sure none are loose or fouled up.
  3. Re: stuttering A4.. ? New to Audi. Just bought it !!
    Hi Road-Rager
    Thanks for taking the trouble to reply. Iam about to take it to a local independent Audi specialist for a check over and diagnostic test....if i can drive it there !!!
    Its running really rough....popping and spluttering.....not good.
    I will let you know the outcome.
    Not off to a good Audi ownership start .
    I knew I should have stayed with Toyota...virtually trouble free motoring over the past 20 odd years with a couple of Corolla's and Celica's !!!
  4. Re: stuttering A4.. ? New to Audi. Just bought it !!
    Good luck, I'm sure it will be nothing too serious. let us know how you get on.
  5. Re: stuttering A4.. ? New to Audi. Just bought it !!
    Lincoln, NE, USA
    are u getting a cel?
  6. Re: stuttering A4.. ? New to Audi. Just bought it !!
    Sorry, what is a cel ??
    Dave
  7. Re: stuttering A4.. ? New to Audi. Just bought it !!
    Blairgowrie
    Could try removing throttle body and giving it a real good clean. That was what i had to do to mine and its running superbly now, even mpg is up.
  8. Re: stuttering A4.. ? New to Audi. Just bought it !!
    Thanks for the replies. Lofty79...that sounds like a good idea, giving the throttle body a good clean. A mechanic friend also mentioned this. I believe a new one is quite an expensive item to buy.
    I am awaiting the response from the local Audi indie garage to see what needs doing.
    I am not that mechanically minded to be able to start taking throttle body off etc.
    I hope its nothing too serious (expensive) and I am sure it will be fine once sorted.
    I will let you know what the garage says.
    In the meantime any other advice would be welcome nd thanks again for the replies.
    What a nice lot of friendly people there are on here.
    Regards
    Dave
  9. Re: stuttering A4.. ? New to Audi. Just bought it !!
    Blairgowrie
    Should just be a case of 1 breather 2 water pipes and 4 alan key bolts and itll come off, inside of it needs a dam good clean and around edge of the choke flap. Throttle body is the part that holds the throttle cable on top of it.
  10. Re: stuttering A4.. ? New to Audi. Just bought it !!
    Lincoln, NE, USA
    Quote Originally Posted by dpnewbold View Post
    Dave
    check engine light
  1. Just bought an Audi!
    By Soulgirl in forum New Member Introductions
    Last Post: 07-03-2008, 11:12 PM
  2. just bought audi a3 1.8t
    By vorty73 in forum Audi A3 - Archive Topics
    Last Post: 03-03-2008, 11:00 PM
  3. Just bought my first Audi!!!
    By red_avant in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 31-01-2008, 04:01 PM
  4. Just bought Audi 80 TDI - need some help
    By uknowiama in forum 80 - 90
    Last Post: 28-12-2007, 08:59 AM
  5. Just bought an Audi S8
    By All Types in forum Chat - Completely Off Topic
    Last Post: 22-11-2006, 10:32 PM
