Thread: Bora 2.0i Service Schedule Missing
  1. Bora 2.0i Service Schedule Missing
    Hi everyone,
    Just bought a Bora today, 1999 2.0i SE Manual, nice!
    Bought it privately and came with all the car info but only just realised that the 'Service Schedule' section from the folder is missing!
    It does have with it a separate VW 'service schedule' booklet but its a duplicate and has all the service history stamped in that, but no info on when things need to be done. I can only presume that the lost service schedule included the details of what gets serviced when.
    Does anyone have a copy of the service schedule's for a Bora 2.0i 1999 that they can send over? Even a pic of their booklet will do. Need to know when cam belts, drive belts, gear oil, etc need to be done.
    Many thanks
    zimbora
  2. Re: Bora 2.0i Service Schedule Missing
    One more question if the guru's can help:
    One of the service entrys in the duplicate book has 'BFS' and another has 'BFC' written next to the service that was done, eg '10K BFS'.
    Any ideas what BFS and BFC might mean?
  3. Re: Bora 2.0i Service Schedule Missing
    Apr 2007
    N.Ireland
    I have a haynes manual that tells you all of the service interval details, I'll type it out for you. Don't know what BFS or BFC stand for.
    Golf GTD 2.0 DSG (ACC | Winter Pack | 18" Vancouvers | RCD510 | Parking Sensors, Rear Camera & Park Assist | Cruise Control | Flat Tyre Indicator | Luxury Pack | Rear Airbags)
  4. Re: Bora 2.0i Service Schedule Missing
    Apr 2007
    N.Ireland
    SERVICE INTERVALS - PETROL ENGINES (Standard Service Intervals, Not Long-Life Service)
    10K Miles Service
    • Change engine oil and filter
    • Check front and rear brake pad thickness
    20K Miles / 2 Years Service
    • Check condition of exhaust system and mountings
    • Renew brake fluid
    • Check underbonnet components and hoses for fluid and oil leaks
    • Check condition of auxiliary drive belt
    • Check coolant/antifreeze concentration
    • Check brake hydraulic circuit for leaks and damage
    • Perform headlight beam adjustment
    • Renew pollen filter
    • Check manual transmission oil level
    • Check underbody protection for damage
    • Check condition of driveshaft gaiters
    • Check steering and suspension components for condition and security
    • Check battery condition and electrolyte level
    • Lubricate hinges and locks
    • Check condition of airbag unit
    • Check condition of windscreen/tailgate washer system
    • Scan ECU for logged faults
    • Check operation of sunroof and lubricate guide rails (if applicable)
    • Carry out road test and check exhaust emissions
    40K Miles / 4 Years Service
    • Renew air filter element
    • Renew spark plugs
    • Check power steering hydraulic fluid level
    • Check automatic transmission fluid level
    • Check automatic transmission final drive oil level
    60K Miles Service
    • Renew the timing belt and tensioners
    If it were me, I would change the spark plugs and air filter every 20K rather than every 40K
  5. Re: Bora 2.0i Service Schedule Missing
    Thanks Chris!!!!
    Just what I needed, will prob grab a copy of the Haynes book asap, need to change aux belt - its a bit tired
  6. Re: Bora 2.0i Service Schedule Missing
    n.ireland
    i think bfc means brake fluid change, hope this helps
  1. Service schedule?
    By RobBentley in forum Passat - B5 Forum - 1997 -2005
    Last Post: 11-03-2008, 10:44 AM
  2. 2.0 tdi service schedule
    By Paul_mkV_golf in forum Golf MK5 - 2004 - 2009
    Last Post: 02-01-2008, 03:45 PM
  3. A4 TDI 100 service schedule
    By wickerman in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 21-02-2007, 10:41 PM
  4. A3 Service Schedule
    By dskies in forum Audi A3 - Archive Topics
    Last Post: 12-02-2007, 01:30 PM
  5. Service schedule
    By msond in forum 80 - 90
    Last Post: 01-04-2005, 09:48 PM
