Thread: 2005 caddy Main fuseboard probs
Results 1 to 10 of 10
  1. 2005 caddy Main fuseboard probs
    Buckinghamshire
    Hi to all that can help !
    My 2005 Caddy van (1.9 Tdi)
    Broke down last thursday pm. The engine cut out and dashboard lit up like a xmas tree. i eventually got it to a spanner who says its the main fuseboard under the bonnet. Apparently there is a poor connection to the relay that controls the fuel pump etc. Then to prove his point he removed the relay, stuffed a piece of wire into 2 of the holes and the pushed the relay back in. he claimed that the extra wire would take up any slack in the connection and Kapow ! My Caddy was running again. Lol
    Can anybody tell me if this is a common fault or would the purchase of a new main fuseboard (£190.73 +vat and fitting) be the ideal solution ?
    Cheers !
  2. Re: 2005 caddy Main fuseboard probs
    135 Post(s)
    2038 Post(s)
    I have never seen one go wrong, it may be the relay command at fault. What is the engine code?
  3. Re: 2005 caddy Main fuseboard probs
    Buckinghamshire
    Not to sure but i think the Engine code is BJB if that makes any sense
    Cheers !
  4. Re: 2005 caddy Main fuseboard probs
    135 Post(s)
    2038 Post(s)
    Yes, BJB makes sense. The fuel pump relay is number 449 and is under the dash inside the car. What is the number of the relay he hot wired?
  5. Re: 2005 caddy Main fuseboard probs
    Buckinghamshire
    Relay under the bonnet that was " Hot wired " is 458
    Cheers !
  6. Re: 2005 caddy Main fuseboard probs
    135 Post(s)
    2038 Post(s)
    That is J317, the main battery line 30 power relay for the engine electronics, fed from the battery live line and command powered from fuse 26 (5 amp) and controlled by the engine ECU. This relay has 4 pins that are used, 30 (socket 1 on the board), 87 (socket 2), 86 (socket 3) and 85 (socket 4). I presume he has jumped 1/30 to 3/86, is this the case?
  7. Re: 2005 caddy Main fuseboard probs
    Buckinghamshire
    He hasnt actually jumped anything, He just stuffed a piece of wire into the hole and cut it off, Then repeated it again in another hole. So he hasnt actually bridged/Shorted anything, it just made the connection in the fuseboard to the relay tighter.
    To be fair, its all a bit confusing for me. I just wanted to know if this was a common fault and/or would simply replacing the very expensive fuseboard fix the problem (as it may not be the actual problem, it may be something else)
    Cheers !
  8. Re: 2005 caddy Main fuseboard probs
    135 Post(s)
    2038 Post(s)
    Odd!
  9. Re: 2005 caddy Main fuseboard probs
    Buckinghamshire
    I fitted a new fuseboard and all is well now.
    Cheers !
  10. Re: 2005 caddy Main fuseboard probs
    135 Post(s)
    2038 Post(s)
    You have to ask yourself why the relay plate/fuse board became faulty, it is not normal.
  1. Main headlamp failure
    By rumples in forum Golf MK3 - 1993 - 1999
    Last Post: 15-08-2008, 06:12 PM
  2. 2005 vw caddy stereo
    By gerrysmith in forum The Commercial Range
    Last Post: 07-04-2008, 09:51 PM
  3. MAIN dealer Service/or not??
    By rtassap in forum New Member Introductions
    Last Post: 26-01-2008, 05:01 PM
  4. Main Dealerships
    By timo'sullivan in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 30-07-2007, 09:42 PM
  5. No main beams?
    By WJI8985 in forum 80 - 90
    Last Post: 01-07-2007, 06:52 PM
