Thread: help needed !!!
Results 1 to 1 of 1
  1. help with passat auto box problems please
    Dec 2006
    hi ther just looking for a bit of help . i have just purchased a 1998 passat tdi automatic estate and it has problems with the auto box. if you put it in drive its sticks in third gear when pulling off and driving along . you can use the lever to manually select first,second.then third but it doesnt go into fourth its has had the output speed signal sensor replaced by the last owner but apart from that i know no more about it .any help would be gratefully received
  1. 04 TDI....help needed!
    By white_lightning in forum Passat - Archive Topics
    Last Post: 20-09-2007, 09:24 PM
  2. Help needed
    By scott-mk3 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 22-06-2007, 02:10 PM
  3. A3 help needed
    By squinty in forum Archive posts
    Last Post: 28-05-2007, 04:46 PM
  4. help needed
    By kharva007 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-05-2007, 06:36 PM
  5. help needed
    By krazyneil in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-04-2007, 03:16 PM
