Thread: VW transporter t4 no power assist on breaks
Results 1 to 1 of 1
  1. VW transporter t4 no power assist on breaks
    Hi I have a t4 P reg transporter which I have had for years now. I bought it 2nd hand and immediately I noticed the breaks were hard when you first started the van. Clearly the vacuum was not working for the power assist. They cut in after a few mins or high reving or if you go around the corner in the van. I have had 3 new vacuum pumps, a new server and the main VW dealer spent about 8 hrs on it and basically said that they would have to rebuild the engine if I wanted to fix it. It is worse in cold weather and really does need to engage the gears for the vacuum to start - ie you can't just leave it on for 10 mins for the vacuum to start. The main dealer did try something with the cambelt and basically thought it might be the oil pump.
    If you pump the breaks continuously you can cause the breaks to go hard but you have to pump fairly hard to do this and be stationary or the vacuum remains.
    Anyone had a similar problem or got any ideas.
    Appreciated any thoughts ?
    Last edited by HP_12345; 06-04-2008 at 11:22 PM. Reason: changed transport to transporter in tittle
  1. Steering assist change with VAG-COM for MK5
    By Perpetuus in forum VCDS - General Questions
    Last Post: 08-03-2009, 08:44 AM
  2. Need help with adjusting steering assist level on GTI
    By Perpetuus in forum Golf MK5 - 2004 - 2009
    Last Post: 01-06-2008, 05:18 PM
  3. Coleford Carinival of Transport
    By foreststu in forum Shows & Events
    Last Post: 17-03-2008, 06:19 PM
  4. VW assist
    By thirty3 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 23-06-2007, 08:52 PM
  5. breaks
    By garying3980 in forum Passat - Archive Topics
    Last Post: 10-02-2007, 06:15 PM
