Thread: HELP ! Need location of convenience control module in 2002 A4 tdi Quattro please? Windows/mirrors/light failed??
Results 1 to 8 of 8
  1. HELP ! Need location of convenience control module in 2002 A4 tdi Quattro please? Windows/mirrors/light failed??
    Hi all,
    Wonder if any of you Audi gods can help me please.
    Having spent hours doing a search I think the "convenience control module" is at fault.
    Symptons:
    Electric windows dont work on any switch
    Interior light stays on in door position
    Electric mirrors not working
    No illumination on the drivers control panel switches
    When arming the locks theres no flash from the indicators
    Can hear a very faint whirring clicky type noise from behind the dash
    All other window buttons illuminated
    UPDATE: VAG-COM Gives following code 01331 - Door Control Module: Driver Side (J386)
    49-00 - No Communications
    Anyone had these symptons before?
    Where is the control module located and what does it look like?
    I have VAG-COM is there anything I can do to check it?
    How much is a new control module and do you think I could fit it myself, I understand I may have to re-code the keys (I will have a read up on that later)
    Any advice would be greatly appreciated
  2. Re: HELP ! Need location of convenience control module in 2002 A4 tdi Quattro please? Windows/mirrors/light failed??
    134 Post(s)
    2007 Post(s)
    Under the carpet on the left hand front floor.
  3. Re: HELP ! Need location of convenience control module in 2002 A4 tdi Quattro please? Windows/mirrors/light failed??
    Thanks crasher, much appreciated.
  4. Re: HELP ! Need location of convenience control module in 2002 A4 tdi Quattro please? Windows/mirrors/light failed??
    Just back from up North and plugged it into vag-com.
    One of the codes I got was as below, is this typical of the "CONVENIENCE MODULE" failure or could it just be the actual switch unit on drivers side?
  5. Re: HELP ! Need location of convenience control module in 2002 A4 tdi Quattro please? Windows/mirrors/light failed??
    Just posting bits of info as I find them so at least it will help someone doing a search in the future Feel free to post suggestions or I dont mind talking to myself like a crazy person
    Output on
    printer V.A.G
    1551
    Possible causes of fault Fault remedy
    01331
    Door control
    unit, driver's
    side -J386
    No
    communication
    - Data bus wiring damaged or open circuit
    - -J386 defective
    - Fault finding according to current flow diagram
    => Current Flow Diagrams, Electrical Fault-
    Finding and Fitting Locations
    Replace -J386
  6. Re: HELP ! Need location of convenience control module in 2002 A4 tdi Quattro please? Windows/mirrors/light failed??
    Could be any number of items in the controil flow - but I'd go through following sequence in order:
    • Wiring loom - check carefully between A pillar and door as wire breakage can occur here - and could induce the sort of multiple issue you report
    • Door control module - removal of door trim and access is not too bad - but not sure how one can trouble shoot this without a substitute part. I believe the control to be built into the window motor assembly - somone correct me if I'm wrong as I'm only recalling what I though I had observed in some of the current flow diagrams. If this is indeed the case - it might be possible to swap driver / passenger door items - simply as a test rig to eliminate components in trouble shooting steps?
    • Convenience module - access not too bad though some trim to play with - but same as door module - how to test without substitute. You could visually inspect at least as some isolated cases of water damage have been observed through water penetration at bulkhead
    There may be other suggestions on the best order to proceed - but I'd go this way given symtpoms, ease of elimination and ptobable causes.
  7. Re: HELP ! Need location of convenience control module in 2002 A4 tdi Quattro please? Windows/mirrors/light failed??
    All sorted now yipeeeee
    Thanks Spr0cket for the guide and suggestions, really appreciated !!
    Just to update:
    2 wires in the loom beween the door and car had broken off so spent most part of the day re-wiring it back up, all is good for now...Its the wifes car I have always been a Jap man personally, has restored my faith in the Germans !
    Again thanks for all your help and taking the time to write that mini guide for me sprocket your a star cheers...
  8. Re: HELP ! Need location of convenience control module in 2002 A4 tdi Quattro please? Windows/mirrors/light failed??
    Glad I could help - and congrats on getting it resolved
  1. Vag com and convenience module
    By dysdera in forum VCDS - General Questions
    Last Post: 23-06-2009, 04:03 PM
  2. fan control module
    By chris954 in forum Golf MK4 - 1999 - 2004
    Last Post: 07-03-2008, 05:43 PM
  3. Windows and mirrors not working?
    By B45HER in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 17-02-2008, 08:03 PM
  4. Location of Convenience control on Alembra
    By bravo6 in forum Touran - Sharan - Caravelle
    Last Post: 16-02-2008, 10:53 PM
  5. Convenience system central control
    By ukheman in forum Golf MK5 - 2004 - 2009
    Last Post: 27-12-2007, 06:37 PM
