Thread: No Reverse !
Results 1 to 8 of 8
  1. No Reverse !
    Hi Guys, as a newbie to your forum i'd like some help please ?
    I've just bought a '99 1.8 non turbo mk4 Golf, lovely car but I can't engage reverse gear ?
    Now i've had a look under the bonnet and there seems to be a plastic part thats broken off. It looks a bugger to replace !
    Does anyone know what this part is called ?
    Is there a part number ?
    And is it easy to fix ?
    I've attached a couple of pictures to show you what i'm babbleing about.
    Thanks for you helps guys
    Mark
  2. Re: No Reverse !
    134 Post(s)
    2007 Post(s)
    I think the piece that is broken is called a “driver” by VW and is part number 1J0 711 256 costing £10.16 from VW. For the 2000 model year, the design was completely changed.
  3. Re: No Reverse !
    Thanks Crasher, any idea how its replaced ? and what the labour costs could ? dare I ask !
  4. Re: No Reverse !
    134 Post(s)
    2007 Post(s)
    It is quite quick to change as long as it isn't stuck in the ally housing, should take no more than half an hour if it comes out easily.
  5. Re: No Reverse !
    well that sounds promising, thanks Crasher. One more thing though is there a guide on how to do this job or what else needs to come off ?
    Regards
    Mark
  6. Re: No Reverse !
    All done now Steve, thanks for you help.
    Even had time for an oil change
    Mark
  7. Re: No Reverse !
    A, A
    Quote Originally Posted by yorkielad View Post
    Mark
    Nice one, was this the cause of no reverse gear ?
    Just another B7 Estate
  8. Re: No Reverse !
    It was the Actuating arm that broke causing no reverse gear. It's made of plastic so was bound to brake at some point, but then again it's done work for 90,000 mls !
    Mine is a '99 model and apparently by the 2000 model the problem had been rectified, typical !
  1. reverse switch
    By danny710 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 26-01-2010, 11:55 PM
  2. baulking on reverse
    By mike simpson in forum Golf Plus
    Last Post: 28-01-2008, 05:33 PM
  3. Reverse Lights
    By cb1 in forum Audi A3 - Archive Topics
    Last Post: 12-11-2007, 11:20 PM
  4. HELP! NO REVERSE LIGHTS
    By ljkbrierley in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 30-12-2006, 06:12 PM
  5. MK3 GTi 8v Problems with reverse
    By Mowgs in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 12-08-2006, 10:45 AM
