Thread: Adding a Amp onto Concert II
  1. Adding a Amp onto Concert II
    hi guys i want to add a amp on to my concert II headunit unit,how is this done and isit possible?
    i have the bose setup in my a4 at the moment but want i little more bass,so isit possible to add a extra amp?
    and how is this done?
  2. Re: Adding a Amp onto Concert II
    Bournemouth
    i cant give you any definites, but here are some possibilities to look at:
    i believe the bose head units have an extra connector to supply the bose amp. the feeds are likely to be at line level (similar to line outs on an aftermarket external amp compatible head unit) you could try connecting into these to feed the new amp. this may degrade the sound that the bose speakers produce....
    try rigging up the "normal" (non bose amp connector) speaker connections to a test speaker. if they are still running, then the internal amp of the head unit is still running. you could buy an amp that has "high level inputs", then you can just feed in the normal speaker connections.
    or investigate replacing the bose amp with one that has more channels (for extra sub), or is more powerful to get that bass sounding crisper/harder.
    hope this is of some use
  1. adding a new subwoofer?
    By brianthornton in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 27-01-2009, 08:32 AM
  2. adding turbo?
    By squirrel4207 in forum Golf MK3 - 1993 - 1999
    Last Post: 04-04-2008, 04:26 PM
  3. Adding Fuel...Cut out problem
    By dickturpin in forum Passat - B5 Forum - 1997 -2005
    Last Post: 17-05-2007, 10:04 PM
  4. adding a Cd changer to concert A4 2006 model
    By bigwheels280 in forum Audi A4 - Archive Topics
    Last Post: 16-05-2007, 12:28 PM
  5. Adding Xenons to a 2006 A6
    By PAH in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 08-11-2006, 02:02 PM
