Thread: 1.9tdi bora sport (130) 2001 overheating
  1. 1.9tdi bora sport (130) 2001 overheating
    hi , new guy, had a look round but cxant find much on over heating problems,well not with the bora anyways.
    sold my 1.9 to my nephew a bout 4 years ago, and he is having problems with over heating, he basically cant go over 40 , has no heating in the car,and has so far paid for the following
    new rad,2 new thermostats, new coolant bottle, new water resevoir
    some have said the head gasket may have gone, what else could it be
    any idea's
    cheers
    A-I-S
    there can be only one
  2. Re: 1.9tdi bora sport (130) 2001 overheating
    Mar 2007
    Yorkshire
    Quote Originally Posted by as-i-said View Post
    any idea's
    cheers
    A-I-S
    Water pump, or air in cooling system?
    Coolant bottle and water resevoir? Do you mean the header tank?
    2007 Audi A6 3.0 TDi quattro S line manual saloon
    1975 Rover P6 4000S 5 speed
    Time flies like an arrow
    Fruit flies like a banana
  3. Re: 1.9tdi bora sport (130) 2001 overheating
    2024 Post(s)
    So no one mentioned the water pump, no pumping = no circulation.
  4. Re: 1.9tdi bora sport (130) 2001 overheating
    sorry , yes the water pump has been changed, and 4 times, all under warrenty from the first change, the air in the system sounds interesting though
    yes header tanks
    do you guys think the over heating and no heater are related, its got climate control, the chill works , just not the heat
  5. Re: 1.9tdi bora sport (130) 2001 overheating
    2024 Post(s)
    New water pump and no heater says air in the system but it should self bleed so air is being introduced and the PD is getting a reputation for heat gasket leakage. If you pull the head, remember that VAG instruct that the head must not be skimmed.
  6. Re: 1.9tdi bora sport (130) 2001 overheating
    this sounds promissing, and excuse my ignorance, PD?
  7. Re: 1.9tdi bora sport (130) 2001 overheating
    2024 Post(s)
    Pumpe Düse, pump injector-no separate injector pump.
  8. Re: 1.9tdi bora sport (130) 2001 overheating
    cheers crasher , ill pass this on and hope he can sort it
    helpful friendly forum you guys have here
    cheers
    john
  1. Bora 1.9 STDI Overheating + Dead?
    By matti100 in forum Bora - 1998 - 2005
    Last Post: 12-04-2008, 09:08 PM
  2. Overheating and Rough Idling Bora PD100SE
    By amygoodness in forum Bora - 1998 - 2005
    Last Post: 29-01-2008, 08:52 AM
  3. 2001 Tdi130 Overheating @ Higher Speed
    By oxoboy in forum Passat - Archive Topics
    Last Post: 01-01-2008, 10:04 PM
  4. 2001 VW Passat Overheating Problems?????
    By Future in forum Archive posts
    Last Post: 12-12-2007, 11:39 AM
  5. VW Sharan 1.9tdi sport 2001
    By chalkmyster in forum Touran - Sharan - Caravelle
    Last Post: 25-09-2007, 02:44 PM
