Thread: P reg golf diesel glow plug light flashing but goes out after a couple of mins
  1. Cool P reg golf diesel glow plug light flashing but goes out after a couple of mins
    I have a mk3 golf diesel non turbo. When I got the car the glow plug light didnt work so I removed the clocks and fitted a new bulb. Now when I start the car from cold the light works as it should until the engine is started, it then flashes for a couple of minutes. It stops flashing at the same time as the engine revs pick up a bit. The car has got a different engine in it as the one it came with was Knackered, I didnt change the fuel pump of the old engine I just ran an ingnition live to the solenoid. Do these golfs have some kind of cold start/choke on them the it could be related to. Any help or info would be much appreciated.
    Cheers.
    Biogodbrand.
  2. Re: P reg golf diesel glow plug light flashing but goes out after a couple of mins
    134 Post(s)
    2016 Post(s)
    What is the engine code?
  3. Cool Re: P reg golf diesel glow plug light flashing but goes out after a couple of mins
    That was quick mate. The engine code is 1Y.
    Cheers.
    Biogodbrand.
  4. Re: P reg golf diesel glow plug light flashing but goes out after a couple of mins
    134 Post(s)
    2016 Post(s)
    That indicates that a fault code is stored. You need to get a fault code scan carried out on the diesel pump electronics control unit, address 41.
  5. Re: P reg golf diesel glow plug light flashing but goes out after a couple of mins
    Thanks for the quick response. My mate has got a lead and software on his laptop that might be able to sort it.
    Cheers.
    Biogodbrand
  1. Flashing Glow Plug Light??
    By TDi_B5 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-11-2009, 09:49 PM
  2. glow plug light flashing
    By rollingroadtune in forum Alhambra
    Last Post: 12-05-2009, 03:25 PM
  3. 1993 diesel, Glow Plug light Flashing/Clicking?
    By sara1993 in forum Early Passat Forum - Pre 97
    Last Post: 16-07-2008, 01:19 AM
  4. flashing glow plug light !help!
    By Bora Boy in forum Archive posts
    Last Post: 09-12-2007, 12:11 PM
  5. flashing glow plug light
    By imanutter in forum The Commercial Range
    Last Post: 02-12-2007, 07:12 PM
