Thread: not the head gasket, but what colud it be???
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 35
  1. not the head gasket, but what colud it be???
    Mar 2008
    Oxfordshire
    i had a problem with my golf 2001 gt tdi.
    When i was drivig the car oreheated and computer dislayed `check coolant`.
    when e checked it i saw that the coolant was spilled out of the tank because the retur pipe from the engine was creating pressure.
    i called the roadside rescue and they said is the water pump.
    sent to the garage and water pump was ok and they dignosed it with head gasket.
    sent to another garage because they asked too much, and after chcking the car they said head gasket is ok.
    then they chacked it with diagnostic tool and noth came up.
    then today he checked the thermostat but still ok.
    Anyone got any idea whats wrong with my car?
  2. Re: not the head gasket, but what colud it be???
    Mar 2008
    Oxfordshire
    anyone plz..
  3. Re: not the head gasket, but what colud it be???
    roadside assistance says water pump, one garage says head gasket,another says niether water pump or head gasket. they have all seen the car,we haven't, but if you are loosing coolant through the tank it has to be coming via the pressure cap,so the pressure cap may need replacing( both garages could have told you that-if the cap has failed the pressure in the system may have been lost causing the coolant to overheat).the thermostat may have failed causing the system to overheat,thus increased pressure blowing the relief cap .
    i can only suggest that you take the car to a reputable garage that knows whats it's doing,because all of the above,plus faulty temp sender/ fan motor could cause the overheating/loss of coolant.
    they all have the same effect(loosing coolant),but show themselves in much different ways,
    (temp of different hoses etc). it's impossible to diagnose without seeing the car--two garages
    have seen it,roadside assistance have seen it, and none agree. suggest another garage mate.
    4th cog,--two to go
  4. Re: not the head gasket, but what colud it be???
    Mar 2008
    Oxfordshire
    thanks for the reply,
    I changed the pressure cap, thermostat, coolant temp sensor, new cam belt and had the car scaned and no fault codes came up.
    bank balance been goin down and no results with the car.
    dont know where to go next.
    i had a suggestion that the head might be cracked but there is no water in the oil, or oil in the water.
  5. Re: not the head gasket, but what colud it be???
    2016 Post(s)
    So you did the cam belt but not the water pump?
  6. Re: not the head gasket, but what colud it be???
    Mar 2008
    Oxfordshire
    the water pump was ok he said.
    2009 A6 2.0tdi Multitronic
  7. Re: not the head gasket, but what colud it be???
    2016 Post(s)
    So he took it out and checked it?
  8. Re: not the head gasket, but what colud it be???
    Mar 2008
    Oxfordshire
    they said they removed the pump and test it.
  9. Re: not the head gasket, but what colud it be???
    2016 Post(s)
    Well as long as they did that is OK as far as impeller security goes but the bearing could still fail before the next belt interval in 4years/60k miles. For how much a pump costs (£37.21 genuine) I would have replaced it to be sure. It is beginning to look like you have a failed head gasket. Remember, if the head is distorted, VW say it cannot be skimmed.
  10. Re: not the head gasket, but what colud it be???
    Mar 2008
    Oxfordshire
    thanks for reply crasher.
    the mechanic opened the car and he said the is not the head gasket.
    after he donne the cam belt, thermostat and some small things and couldnt find the problem he suggested that it could be the cylinder head cracked.
    but he is not sure.
    there is not any water in the oil or oil in the water.
    is there any way i could check to be sure if the head is cracked?
    I have been driving the car over 600 miles since I had this problem, and keeping it on 2000 revs doesnt spill out the water. there is still air goin to the water tank from return pipe but not as much to force the water out.
    my thought is that the garage who checked the water pump did not check the impeller properly, (I think) but I could be wrong.
    any suggestions.?
  1. Head gasket
    By chris90 in forum Golf MK2 - 1984 - 1992
    Last Post: 30-03-2009, 08:34 PM
  2. Head Gasket
    By chris goodwin in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 10-07-2007, 11:14 AM
  3. Head Gasket gone??
    By Gee in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 30-06-2007, 11:08 PM
  4. Head Gasket
    By Mark Ormiston in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 10-01-2007, 10:02 AM
  5. Head gasket help please
    By viking power in forum Archive posts
    Last Post: 12-12-2006, 01:10 AM
