Thread: How to change a battery
  1. Angry How to change a battery
    Dec 2006
    I have had water in the footwell of the rear sea on the drivers side. I went to take out the battery and couldn't get it out. Its a passat 1.9 tdi 2001. I thought I would be able to lift it straight out, but there is no room. Any suggestions?
    london/ UK
    The trim at the bottom of the windscreen will need removing toghether with the wiper arms. That will give you the necessary clearance to get the battery of. Older 96-99 audis had a split trim surround and only the passenger side needed removing. Be carefull as the trims are hard plastics and they snap easily when cold. Good luck. I would check the sunroof drains as when the drains on the bulkhead are blocked, only the front footwels get wet ! If the car has no sunroof, check the door seals by pouring a bucket of watter while someone is inside checking for leaks !
  1. Resetting the radio after Battery Change.
    By Martin Linklater in forum Passat - Archive Topics
    Last Post: 27-10-2007, 11:12 AM
  2. Key fob battery and Key cut
    By richjthorpe in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 12-04-2007, 07:43 PM
  3. How to change battery on remote key fob
    By Jez_A4 in forum Audi A4 - Archive Topics
    Last Post: 10-01-2007, 04:37 PM
  4. 1.8 T battery
    By johnready in forum Passat - Archive Topics
    Last Post: 07-11-2006, 02:08 PM
  5. Problem with 1.9tdi (n-reg) alarm/immob after battery change
    By Trevaaaaaaa in forum Passat - Archive Topics
    Last Post: 06-12-2005, 06:28 PM
