Thread: Mk3 electric windows problem
Results 1 to 8 of 8
  1. Mk3 electric windows problem
    Hi, I have a mk3 golf 1996 with 4 electric windows. The drivers side and both rear windows don't work but the front passenger side works fine?! When I press the drivers side or rear window switches the interior light dims slightly.
    Any advice would be appreciated. Thanks.
    Edit:
    I should have added that when you press the switch which is supposed to control the front passenger side window from the drivers side handle it does not operate the passenger side window. Even though the passenger side window works fine from its own switch!
    Does this indicate some kind of wiring or relay issue rather than a problem with the motors??
  2. Re: Mk3 electric windows problem
    HI It would appear you have a fault with the motors for all 3 windows
  3. Re: Mk3 electric windows problem
    N/A
    it could be that the wiring loom from the 'a' pillar and 'b' pillars on each door is damaged, also maybe faulty switch, relay or blown fuse .
  4. Re: Mk3 electric windows problem
    (When I press the drivers side or rear window switches the interior light dims slightly.) when you say this it means there is some kind of response,therefore i dont think it has anything to do with the switch or the fuses
  5. Re: Mk3 electric windows problem
    Hi, if its a wiring/connection problem in the drivers side pillar would that affect the function of both rear windows too?
    I think the switches are all OK because it doesn't seem probable that all switches would fail including the dash ones and there does seem to be a response in that the dome light dims when the switches are pressed.
    Guess I need to check the pillar wiring!
    Thanks.
  6. Re: Mk3 electric windows problem
    Hi, I'm new to this, but I had a similar problem on my mk3 cabriolet.
    The garage looked into it and couldn't find a problem, but when they cleaned out the drivers side door lock mechanism, all switches and windows worked. Only the drivers window did before.
    Bizarre, but might be worth trying
  7. Re: Mk3 electric windows problem
    Hi, checked drivers door pillar, brown wire was cut!
    Solved drivers side problem, just need to take a look at the back 2 windows now!!
    Thanks for the advice.
  8. Re: Mk3 electric windows problem
    N/A
    No worries ! glad i could help
  1. Electric windows
    By Rick Jay in forum Touran - Sharan - Caravelle
    Last Post: 01-03-2010, 01:14 PM
  2. electric windows problem
    By kernowk in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 27-01-2008, 07:07 PM
  3. t5 electric windows
    By PAULRYAN52 in forum The Commercial Range
    Last Post: 03-01-2008, 11:03 PM
  4. A4 Cab Electric Windows
    By papalion in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 03-09-2007, 10:38 PM
  5. VW Golf Mk4, electric windows problem??
    By churd_smith in forum Golf MK4 - 1999 - 2004
    Last Post: 13-05-2007, 07:26 AM
