Thread: adding turbo?
  1. adding turbo?
    can i add a turbo to my 1994 vw 2.0 in a golf 3 and if so whats a good way to go about it as well as what are some of the issues i may have?
  2. Re: adding turbo?
    Blairgowrie
    There are companies that can turbo charge any car so its definitely do-able, but whether it is a homer or not i dont know
  3. Re: adding turbo?
    ya i was wondering of i can just go ahdead and bolt up teh turbo.. or if i needed teh cooling unit. as well as mabey ajusting my ECU and possible changeing out low compression pistons?
  4. Re: adding turbo?
    ya i was thinking just bolt a turbo up and drop in the cooling unit for it weather i need to to change teh comression ratio or ajust my ecu or not .. I'm looking into purchashing teh vagcom product if thats a good idea or not any other good products out there i should invest in
  5. Re: adding turbo?
    131 Post(s)
    1976 Post(s)
    Just bolt a turbo up, I like that-funniest thing I have read today!
    The compression ratio needs to be dropped from 10.0:1 to around 8.0:1 by using low compression pistons or bodge it by fitting a decompression shim and two gaskets.
    Do the sensible thing and fit the 1.8T from a Golf 4/Bora/Leon/Octavia etc.
  6. Re: adding turbo?
    Apr 2007
    Lancashire
    With the amount of changes, and the costs involved, it is generally much more economical to source an original turbo engine & management system to transplant. (1.8T etc), or buy a turbo car.
    Personally the only time i would consider turbo'ing a normally aspirated engine would be if it has variable valve timing.
    Otherwise, turbo & management, possible strengthened internals, compression (gasket/pistons), manifolds exhaust, ECU, suspension, brakes etc etc.
  1. adding a new subwoofer?
    By brianthornton in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 27-01-2009, 08:32 AM
  2. 97 (N) Polo 1.0L... adding gearbox oil
    By riyaz3000 in forum Polo - Derby - Lupo - Fox
    Last Post: 06-11-2007, 11:12 PM
  3. Adding Fuel...Cut out problem
    By dickturpin in forum Passat - B5 Forum - 1997 -2005
    Last Post: 17-05-2007, 10:04 PM
  4. Adding new switch to dash..
    By Nebooaw in forum Passat - Archive Topics
    Last Post: 02-03-2007, 08:40 AM
  5. Adding Xenons to a 2006 A6
    By PAH in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 08-11-2006, 02:02 PM
