Thread: Whooshing Noise When I accelerate
Results 1 to 9 of 9
  1. Whooshing Noise When I accelerate
    Dec 2006
    I have A4 2.5Tdi and I have noticed that when accelerating ( not hard) that I get a whooshing/whistleing noise. It happens around 2/2.5RPM. I dont think it is a gearbox whine could it be anything else? I thnk though that my clutch may be on its last legs could it be anything to do with that? Cheers Len
  2. Re: Whooshing Noise When I accelerate
    Mar 2008
    hi , im new here but seen your thread, I have a passat 130 , when i got it i used to get a hissing noise, but garage said it was noisy turbo ..but last year it got louder turned out it was my intercooler i was mad as warranty had expired but volkswagen paid half as i had complained earlier, I would check all your intercooler pipes first as i had 2 of them go while under warranty,
    hope im wrong and its a simple thing
  3. Re: Whooshing Noise When I accelerate
    May 2007
    sounds like a leak from the fresh air side of the turbo, either from turbo to intercooler or intercooler to inlet manifold
    check hoses are fully fitted, and not split. If you have a leak you will be loosing a lot of power
  4. Re: Whooshing Noise When I accelerate
    Dec 2006
    Thanks guys, so good news then and hopefully not too expensive. I shall check the hoses and let you know
  5. Re: Whooshing Noise When I accelerate
    Dec 2006
    Quick update, there is some fluid leaking from the engine and Ive collected some and it smells like diesel and is greeny blue in colour which I suppose would support being an intercooler pipe. The Audi specialist said that is what it is likely to be and hes gonna fix it for me tomorrow. I shall let you know how it goes. Thanks
  6. Re: Whooshing Noise When I accelerate
    Dec 2006
    Another update it was the fuel pipe on the drivers side that had corroded and was leaking fuel when the iginition was switched off. Anyway is been repaired.
  7. Re: Whooshing Noise When I accelerate
    Mar 2008
    Basingstoke, Hants
    Well I have the same "issue", but I have no loss of power at all - my MPG is around 45 to 50 on average. And I don't have a leak - that I can see anyway! But I can hear mine at very low revs, moving from stationery to around 20 mph I guess, then I can't hear it anymore. Does this mean something different or do I need to check pipes etc. I'm not experienced in the engine bay - what do I need to check for?
    Regards.
    Regards, David.
    02/2002 A4 Avant B5, 2.5 TDI SE Multitronic
  8. Re: Whooshing Noise When I accelerate
    Mar 2007
    Bedfordshire
    Intercooler, happened on my old car
    Current Car: Skoda Octavia vRS Hatch 2.0TDi 170 CR in Candy White
    Outgoing Car: 2007 56 Plate Audi A3 Sport Sportback 2.0TDi 170 PD in Black
  9. Re: Whooshing Noise When I accelerate
    Dec 2006
    It turned out that it was one of the seals on the intercooler. And for the genuine Audi part it was £250. Mine made a noise when i accelerated hard or revved it hard in neutral.
  1. No Acceleration and jerky when it does accelerate!
    By michelle in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 07-12-2009, 07:58 PM
  2. VW passat 1.9tdi accelerate on its own
    By newboy999 in forum New Member Introductions
    Last Post: 06-01-2008, 10:00 PM
  3. Loss of Power, Smoke and Whooshing Noise
    By MikeA4tdi in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-11-2007, 07:49 PM
  4. Whooshing Sound!
    By chrisball666 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 09-09-2007, 09:03 PM
  5. please help new mk3 owner car doesnt want to accelerate
    By sponger2 in forum Golf MK3 - 1993 - 1999
    Last Post: 12-01-2007, 01:19 AM
