Thread: Notchy 1st to 2nd gear change
  1. Notchy 1st to 2nd gear change
    kimandsally Guest
    Hi I have a Sharan with the 6 speed box, it's notchy from 1st to 2nd not even from 3rd to 2nd, it's worse when cold but is there all the time.
    It's hard to describe it's like the gear lever tries to go into 2nd but gets a little stiffer then goes in with a small clonking noise.
    It doesn't grind like when the syncro is gone but it doesn't feel right, driven dozens of cars and never felt one quite like this.
    Been in the VW dealer who said they adjusted the linkages and everythings working as normal.
    The thing is every other gear change is repeatable and always feels the same but 1st to 2nd has many different feels to it from stiff and notchy when really cold to clonky when getting hotter.
    Is a gear oil change likely to sort this out?
    Is it normal as thw VW dealer said?
    Any thoughts very welcome.
  2. Re: Notchy 1st to 2nd gear change
    hi was wondering if u got ur sharan fixed?
    i have the same 1st to 2nd gear gear change problems.
    will be gratefull for ur help.
  1. Notchy 1st gear
    By lexmac in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 09-04-2009, 08:28 PM
  2. 80 Coupe sloppy gear change
    By Bloodknock in forum 80 - 90
    Last Post: 02-03-2008, 01:09 AM
  3. When do you change gear?
    By RobBentley in forum Passat - Archive Topics
    Last Post: 28-01-2008, 02:59 PM
  4. Change gear oil
    By UKDK in forum Touran - Sharan - Caravelle
    Last Post: 14-01-2008, 07:48 PM
  5. Touran gear change wail
    By toto in forum Archive posts
    Last Post: 24-12-2007, 10:24 AM
