Thread: Radio Unit RCD500 Failure
  1. Radio Unit RCD500 Failure
    Mar 2008
    Here in Sydney Australia my four month old EOS is great and I have been loving my first VW, but has just had the Radio/CD Unit suddenly fail to switch on. It appears to be electrically dead, no sound, no LCD info and no lights, although the surround button illumination lighting does seem come on intermittently. Have checked all accessible fuses and they seem okay.
    Dealer is heavily booked and has no warranty repair slots for another ten days. Is there anything simple I can do to get the RCD500 to repower??
    Thanks in advance for any advice.
  2. Re: Radio Unit RCD500 Failure
    Quote Originally Posted by zacthedog View Post
    I have a 2006 Passat and this has happened to me three times. Identical symptoms - surround illumination comes on for a minute or so if you attempt to turn it on, but otherwise completely dead. The dealer has been good and has fitted a new unit every time, but I'm not convinced that it won't happen again.
  3. Re: Radio Unit RCD500 Failure
    Sep 2008
    CANBERRA ACT AUSTRALIA
    Hi zacthedog
    Having just joined the forum in order to find a solution to my radio problem experienced today, I see you had an identical problem in March. Presumably yo have had it fixed by now?? Can you give me any advice - I, like you will have to wait at least a week for a booking at the Canberra VW dealer (Lennock Motors)
    My Eos is a DSG TDi bought in January
    Eosthomo
  4. Re: Radio Unit RCD500 Failure
    Mar 2008
    Quote Originally Posted by eosthomo View Post
    Hi zacthedog
    Eosthomo
    Yes it is now repaired - they replaced the complete radio unit - apparently they have had a few like this and blame the radio supplier for a manufacturing fault. The replacement unit works well.
    I am hopeful, in the unlucky event of a major mechanical fault, the VW dealerships will provide some sort of priority on warranty repairs!
  5. Re: Radio Unit RCD500 Failure
    Sep 2008
    Thanks Zacthedog. I'll try and give Lennock Motors a heads-up and hopefully they may have replacement unit on hand when I take the Eos in.
    Eosthomo
  6. Talking Re: Radio Unit RCD500 Failure
    Sep 2008
    Just thought I would let you know that Lennock's replaced the whole unit this morning. They even happened to have one in stock to carry out the replacement straight away.
    This may have been the result of an earlier e-mail I sent giving them a "heads-up" on what I thought was wrong and that it was likely that a replacement was probably required and the ensuing phone call stating that they di not carry such stock as it was VW policy not to supply replacement units until problems had been verified etc. I then launched into a rather robust response on what I expected for a $60,000 car and said I would discuss it further when I brought the car in.
    Anyhow the bottom line is that the unit was replaced in two hoours and the 6 CDs were retrieved and returned. So we will keep our fingers crossed
    Eosthomo
  1. Body Control Unit Failure
    By Kevin Costello in forum Passat - B5 Forum - 1997 -2005
    Last Post: 18-02-2008, 06:40 PM
  2. RCD200 or 300 radio/cd unit
    By laujen in forum Passat - B5 Forum - 1997 -2005
    Last Post: 11-02-2008, 12:48 PM
  3. gamma radio head unit
    By passatmick in forum Passat - B5 Forum - 1997 -2005
    Last Post: 30-11-2007, 10:10 PM
  4. Bulb failure unit with towbar
    By wanstronian in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 12-04-2007, 09:55 PM
  5. Replace standard radio unit
    By alpappy in forum Eos
    Last Post: 24-02-2007, 08:39 PM
