Thread: ADY engine problems
  1. ADY engine problems
    Aug 2006
    Can anyone offer any advice ? I have a 96 Sharan with an ADY engine, done about 150 000 miles. It has a problem that I just can't get to the bottom of. When driving at a constant speed, around 4000rpm, there is this very slight hesitation every now and again, which seems more pronounced when going up a very slight incline. There also seems to be days that the car runs very well, pulls nicely, but then other times when it's like the hand brake is on slightly, sluggish and sometimes hesitates while accelerating.
    I've been to the local mech and so far he has replaced the Hall sender, plugs and lately, the Lambda probe. I have also replaced the plug leads with a Bougi cord set, the Knock Sensor and the Engine Speed Sensor, cleaned the throttle body out till it shines, cleaned out the AMM, all to no avail. I recently got a Vag-com program and read the fault codes and keep getting "00525 - O2 sensor implausible signal - intermittant." Disconnected the Lambda at the plug underneath and checked the Lambda heat voltage with the engine running and get volts that vary between roughly 1 and 10V, this varies very quickly, up and down every second, don't know if this is normal ?. Have checked the continuity between this plug and the ECU and all appears well.
    I also have fairly hard brakes but have replaced all the vacuum lines and checked around the manifold for any leaks, all seems fine there. Am at a loss what to do/look for next.
    Heeelp !!
  2. Re: ADY engine problems
    135 Post(s)
    2042 Post(s)
    You need to replace the Lambda sensor and also the AMM now that you have killed it by cleaning it. Why is this in the Golf section, the ADY engine?
  3. Re: ADY engine problems
    Aug 2006
    My apologies but there appears to be a lot of information in this section regarding the ADY engine as opposed to the Sharan section, that's why I posted my query here.
    I don't think that the AMM is damaged, I opened it up, removed the cover on the probe and sprayed the probe with contact cleaner, also cleaned the gauze screen which seemed to have a slight build up on it.
  4. Re: ADY engine problems
    135 Post(s)
    2042 Post(s)
    Try replacing the lambda sensor first but they normally fail or give bad readings due to a failed AMM and they are very difficult to diagnose. The only sure way I know of is fitting a new genuine VW exchange AMM. In my experience, cleaning the AMM stops them working but the hot wire type are less prone to damage than the hot film type.
  1. 2.3 v5 engine problems
    By jubbly boy in forum Golf MK4 - 1999 - 2004
    Last Post: 08-01-2008, 10:25 PM
  2. a4 tdi engine problems
    By shuggy in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 12-12-2007, 10:57 AM
  3. A6 2.4 Engine Problems Please Help!
    By davo79 in forum Chat - Anything with wheels
    Last Post: 16-09-2007, 07:09 PM
  4. Engine Problems?????
    By NewtoVW in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 08-09-2007, 09:36 PM
  5. !.8t engine problems
    By vw1.8turbo in forum Archive posts
    Last Post: 27-05-2006, 07:26 PM
