Thread: starter motor problem
  1. starter motor problem
    Mar 2008
    hi. can anyone help ! IT's a 18 t bora, jumped in the car a few nights ago, turned the key to fire it up, but stupidly the car was in gear with the handbrake on, it momentarly tried to move forward obviously , on retrying to start the car again, out of gear this time! nothing . checked all fuses in the car , checked fuses on the battery , all ok. starter isn't engaged. What have i done !!!!!
  2. Re: starter motor problem
    at a guess the starter relay may have fried
  3. Re: starter motor problem
    Mar 2008
    thanks for that , i will look into it.
  4. Re: starter motor problem
    Chester-le-Street, United Kingdom
    nick, when you say that you got "nothing" when trying to restart, did you have dash lamps and nothing on the starter, or absolutely nothing,as in no dash lamps?
    first time i was up a ladder i was down a well
    4th cog,--two to go
  5. Re: starter motor problem
    Mar 2008
    hi , thanks for your reply. dash board lights are all on as normal, just no response when the key is turned to start position !
  6. Re: starter motor problem
    ok had a look at haynes manual for wiring diagrams
    copy of picture below
    All copyright from this pic to haynes
    from what i can make out it sounds like there is a relay in the starter itself
    marked up as an M on the bottom of the pic
    will delete the pic in a couple of days as not to upset haynes
  1. touran starter motor problem & coolant loss
    By tambo in forum Touran - Sharan - Caravelle
    Last Post: 01-06-2015, 04:04 PM
  2. Starter Motor
    By Ewster in forum Golf MK4 - 1999 - 2004
    Last Post: 09-03-2008, 11:06 PM
  3. Starter motor
    By schteeeeveeee in forum Audi A3 - Archive Topics
    Last Post: 24-01-2008, 04:32 PM
  4. Serviced my starter motor
    By cbrpaul in forum Chat - Anything with wheels
    Last Post: 29-10-2007, 06:20 PM
  5. Starter motor on its way out ... ?
    By ash in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 07-09-2007, 11:58 PM
