Thread: TDI 115 Brake upgrade help
  1. Question TDI 115 Brake upgrade help
    Mar 2008
    Ipswich
    I currently have a 2000 115 TDI, and the person who had it before me has had some cheap pads fitted. I am going to get some new front discs and pads, but am also interested in putting some bigger ones on. I think the size of standard discs is 256mm, but there are some 280mm for other models (GTI i expect?).
    Are the 280mm discs compatible for my car- it is currently on 15in wheels which may be a problem, but intend to get some new alloys soon. So basically, if I get some bigger wheels, will the 280mm discs go straight on, and how much will the callipers be which go with them?
    Thanks very much in advance!
    Will
  2. Re: TDI 115 Brake upgrade help
    7 Post(s)
    Bit rusty on this but....
    The 115 had 280mm front discs with a FS3 caliper.
    130's, 150's, 1.8t's had 288mm discs with an FN3 caliper.
    The upgrade you will need to swap the hubs as well as the calipers, discs, caliper brackets. An expensive upgrade.
  3. Re: TDI 115 Brake upgrade help
    Mar 2008
    Ipswich
    You will never guess what...you are right! the 115 has 281mm discs to be precise. Thanks very much- i think I will give the bigger brakes a miss then- just upgrade the quality of discs and pads and I think I will be fine!
    Cheers buddy
  1. Brake Upgrade
    By Manny_Sandhu in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 09-02-2008, 06:56 PM
  2. 110/130 brake upgrade
    By madmonk in forum Golf MK4 - 1999 - 2004
    Last Post: 08-02-2008, 10:01 PM
  3. big brake upgrade or not?
    By carrmrc96 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 21-08-2007, 10:47 PM
  4. mk2 golf brake upgrade help!
    By buzmuzguz in forum Golf MK2 - 1984 - 1992
    Last Post: 12-05-2007, 08:12 PM
  5. Brake Upgrade!
    By Mark A4 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 06-03-2007, 07:55 PM
