Thread: VW steering wheel & coming/leaving home lights...
  1. VW steering wheel & coming/leaving home lights...
    Mar 2008
    I have just purchased a 54plate Golf TDI SE and having looked at the manual it says coming/leaving home lights. On the light switch I only have 2 options dipped and main beam. does anyone know if this option can be added and to what cost...
    Also the steering wheel in my car is the old 4 thick spokes, I would like to have the 3 spoke on found on the 06 plate onwards Gt and Gti model.. would anyone have any idea on the costs...
    any help welcome...
    thanks
    Adsy
  2. Re: VW steering wheel & coming/leaving home lights...
    Oct 2007
    Nr Falkirk
    I have a feeling this is a big mod.
    Your going to need the automatic headlight option which requires a sensor which is on the windscreen behind the rear view mirror and all the wiring as well. Then your going to change the headlight switch for the which works with the auto lights option.
    I could be wrong but realistically you'd be better to just buy a car with it fitted.
    Ta Des
  3. Re: VW steering wheel & coming/leaving home lights...
    Mar 2008
    Does anyone know if an auto-electrican can connect the interior lights to headlights. ie. when the interior lights come on so do the headlights...
    is that possible..
    thanks
  4. Re: VW steering wheel & coming/leaving home lights...
    Coventry
    To be honest, these big electrical mods are too costly. It is possible to upgrade the steering wheel from 4 to 3 spoke and even to multifunction (see the How To section), with regard to the coming home lights, this is in the convenience settings (if fitted at the factory) however it is possible to have them enabled if you computer is the right spec. any one with VW assistance or Vag Com should be able to do it. its the same as making your doors lock at +10 mph.
    the best cheapest way is to fit an out sid light with a PIR so when you pull up it comes on automatically.
  5. Re: VW steering wheel & coming/leaving home lights...
    Mar 2008
    hi my computer is the midline one...
    one that has the half screen...
    can you please post a link...
    can a vagcom connect to my midline computer
    thanks for the advise
  6. Re: VW steering wheel & coming/leaving home lights...
    Coventry
    i think mine is the same as yours. I can't change the settings myself, but if i had vag com i could. You need to post up your locating and offer some beer tokens. That may help.
  7. Re: VW steering wheel & coming/leaving home lights...
    Mar 2008
  8. Re: VW steering wheel & coming/leaving home lights...
    Oct 2007
    Nr Falkirk
    Unlucky I've stuggled to find many people up here with Vag-Com.
    Ta Des
  1. Coming/Leaving home lights
    By tony_anon in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-11-2009, 03:28 AM
  2. Replies: 21
    Last Post: 13-09-2009, 07:31 PM
  3. Rattle coming from NS front wheel
    By Kenmay in forum Passat - B5 Forum - 1997 -2005
    Last Post: 03-12-2007, 07:59 PM
  4. water coming from the front wheel arch
    By nerrad in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-07-2007, 11:13 PM
  5. Automatic Headlights with coming home /leaving home facility
    By TonyS in forum Chat - Anything with wheels
    Last Post: 25-06-2007, 03:44 PM
