Thread: help with vagcom
Results 1 to 8 of 8
  1. Question help with vagcom
    Mar 2008
    hi all i have a golf gttdi 150bhp, 2002 model, i recnetly purchased a odb2 lead off good old ebay. i have tried vagcom software from rosstech, version 311 and 409, but when trying to use software i can get it to see the lead and the car but then it crashes, when trying to select any options. i am running vista could this be the problem???/
  2. Re: help with vagcom
    yeap with vista you need to install vagcom in another folder other than program files ( i have it installed on my desktop ). it still crashers with me but to solve the problem right click and select " run as administator " otherwise it crasher every time you select a module
    vista a pain in the butt again
  3. Re: help with vagcom
    A, A
    I Agree, I tried getting someones working on vista with no luck at all.
    Put it on XP, worked a treat.
    Just another B7 Estate
  4. Re: help with vagcom
    Mar 2008
    cool at least i am not alone with this issue, thanks for ur help..
  5. Re: help with vagcom
    Mar 2008
    It could well be the lead. I understand that not many of the 'cheap' leads work very well at all.
  6. Thumbs up Re: help with vagcom
    Mar 2008
    Quote Originally Posted by pgarner View Post
    tried this method and worked perfect, thanks for you help ..
  7. Re: help with vagcom
    I also had this problem with Vista..... and was still crashing out when selected "Run program as an administrator".
    To get mine working I set the program to run in compatibility mode for XP SP2 and also set to "Run this program as an administrator". You can set both of these by right clicking on the program icon and going to properties. Didn't have any problems with the Vag-com folder being in the default location.
  8. Re: help with vagcom
    Quote Originally Posted by Spacey885 View Post
    nah when i tried the compatibility for xp it still crashed even when run as an admin it was only when i reinstalled it on the desktop did it finally allow me to run, although i have checked the run as admin in the properties
    also i found it easier to gain access to the log files, but a shortcut would solve this if its in the program files folder
    1.8T AUQ head standard engine. Newsouth performance Boost, Oil pressure and Temperature gauges, 6 spoke TT alloys and A8 interior light.
    Next engine
  1. Vagcom
    By ashab02 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-01-2008, 08:12 PM
  2. which vagcom??
    By t5psr in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 22-09-2007, 10:55 PM
  3. VAGCOM Help Please!
    By Marco34 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-09-2007, 09:08 AM
  4. VagCom???
    By Mig 117 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 23-07-2007, 06:37 AM
  5. Which Vagcom do I buy
    By Dozz in forum Audi A4 - Archive Topics
    Last Post: 07-06-2007, 11:32 AM
