Thread: abs common fault
  1. Question abs common fault
    Mar 2008
    Hi, just bought a 96 a4 with abs warning light on after a few miles.
    Google brings up loads of info on this "common" fault.
    Most suggest replacing the electrical part of the abs unit located inboard of the l/h front wheel.
    I thought i would find info on this site. Yes i did try search, but do forgive me if there is info on here and i cant find it, i am not really pc wise.
    thanks in advance, gus
  2. Re: abs common fault
    134 Post(s)
    2021 Post(s)
    You need to have a fault code scan done, or at least to try to. If the system won't talk then this is the common issue of corrosion inside the ECU. This can be repaired in some cases, and there are lots of companies who offer the service.
  1. Common components
    By TDiBoraSam in forum Bora - 1998 - 2005
    Last Post: 05-02-2008, 02:19 PM
  2. what are common issues with cabrio?
    By Bright Eyes in forum 80 - 90
    Last Post: 15-09-2007, 12:09 PM
  3. VW common fault
    By sydkhan in forum Chat - Anything with wheels
    Last Post: 15-07-2007, 11:20 PM
  4. s3 common problems to look for !!
    By ian in forum Audi A3 - Archive Topics
    Last Post: 17-01-2007, 10:14 AM
