Thread: A4 1.8T AEB engine 1997 No Spark on 2
  1. A4 1.8T AEB engine 1997 No Spark on 2
    Mar 2008
    My problem is No spark at number 2 plug. A handheld reader shows no codes and the engine check light is not on.
    I have purchased a serial cable to run the VAG-COM but can't get that working yet (Interface not present)
    Ihave replaced the plugs and fitted a new coil on cylinder number 2 but still no spark.
    Any suggestions as to where to move now?
    Does this car have an ignition amplifier anywhere?
    Is it likely to be a the problem.
  2. Re: A4 1.8T AEB engine 1997 No Spark on 2
    2022 Post(s)
    Yes it has an amp, on the bulkhead and they do cause trouble. It changed part number in 97 as the early unit was very troublesome. The early part number is 4D0 905 351 and was used up until chassis number wauzzz8DzV(N or A)244483. Either version costs £136.94 inc. VAT from Audi.
  3. Re: A4 1.8T AEB engine 1997 No Spark on 2
    Oct 2007
    Hi Send your e- mail address and i will send you the procedure to check wiring and power output stage
  4. Re: A4 1.8T AEB engine 1997 No Spark on 2
    Mar 2008
    Quote Originally Posted by kenney View Post
    Thank you
    my email is mick (nospam) @avtec.co.uk
    Remove the (nospam) part
    cheers
    I tried to Pm you but don't have enough posts
  5. Re: A4 1.8T AEB engine 1997 No Spark on 2
    somerset
    8 Post(s)
    My ignition amplifier failed on my 1.8T 1996 a couple of years ago, also no spark on no2 cylinder. As you look into the engine bay, its under the plastic cover on the left by the air cleaner housing, black plastic piece with a plug connector both sides. 99.0 percent sure this is your problem, regards.
  6. Re: A4 1.8T AEB engine 1997 No Spark on 2
    Mar 2008
    Thank you for all the replies. I have confirmed the unit is faulty 4D0 905 351. the diagrams got me thinking and also having read on another forum about a method of testing this out of circuit. I came up with a correct method of verifying this as faulty.
    the methods i read before and tried didn't work and in fact seemed to be incorrect. I took pictures and am writing a tutorial that I can verify as working and correct (previous ones seemed to have the relation between the input and output pins wrong). If of any interest I will make a post containing this tutorial.
    very easy to follow.
    Thank you once again
  7. Re: A4 1.8T AEB engine 1997 No Spark on 2
    Mar 2008
    Just to confirm. I fitted the new ICM today and it has completely cured the car.
    Thank you all for your help with this.
  1. A4 1997 manual the car's engine starts but the car don't move...
    By B. A. in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 13-12-2008, 09:59 PM
  2. A4 1997 manual the car's engine starts but the car don't move...
    Last Post: 12-12-2007, 06:26 AM
  3. Noise in front of engine 2.6 A6 Avant 1997
    By Johan Slump in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 21-07-2007, 04:34 AM
  4. 1.4L 1997 Polo - engine cut out
    By MikeJBro in forum Polo - Derby - Lupo - Fox
    Last Post: 21-05-2007, 11:18 AM
  5. VW 1997 2.0L GTI engine running problem
    By svenandnancy in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 30-01-2007, 12:48 AM
