Thread: flashing diesel coil on dash
  1. flashing diesel coil on dash
    Mar 2008
    dam all going so well as well
    anyway
    got the rclick and moved the rfid into the new fobs and got the keys cut all going well so far
    anyway
    one of the fobs had a rfid in one one did not
    wanted to make sure was working all ok
    so the keys got cut and the first worked spot on
    the second i tried (the one without worked started car but since did not have a rfid in it ) it cut the engine
    yeah all working
    so put the fob with the rfid in and started car yeah
    but 30secs to 1 min later after car started
    the diesel heater light comes on and flashes on and off and keeps doing this
    have taken battery off (for 1-2 mins) hopefully to clear this
    but no go any ideas any one
    thanks
    (i do nto think anything is wrong as this happened afteri put a key in without a rfid)
    but how to reset will power off do it)
  2. Re: flashing diesel coil on dash
    Mar 2008
    vag com cable works a treat
    VAG-COM Version: Release 409.1-S
    Chassis Type: 8D - Audi A4 B5
    Scan: 01,02,03,08,15,17,25,35,45,55,56
    Address 01: Engine
    Controller: 028 906 021 GM
    Component: 1,9l R4 EDC 00SG 1421
    Coding: 00002
    Shop #: WSC 06335
    1 Fault Found:
    17978 - Engine Start Blocked by Immobilizer
    P1570 - 35-00 - -
    Readiness: N/A
    Address 03: ABS Brakes
    Controller: 8E0 614 111
    Component: ABS 5.3 FRONT D11
    Coding: 0273004132
    Shop #: BB 24303
    No fault code found.
    once i cleared this error all back to normal
    yeah
  1. Loss of power, flashing coil light
    By dazzaroon in forum Touran - Sharan - Caravelle
    Last Post: 13-03-2008, 10:37 PM
  2. Flashing Sign on Dash
    By eskimo in forum Golf MK3 - 1993 - 1999
    Last Post: 10-12-2007, 08:21 PM
  3. Sharan tdi 1997 - No brake lights and Heat coil light flashing
    By hawkz_2002_uk in forum Touran - Sharan - Caravelle
    Last Post: 16-09-2007, 07:20 PM
  4. HELP! - coil light flashing on mk4 golf...
    By bobsonic82 in forum Chat - Anything with wheels
    Last Post: 19-08-2007, 08:21 PM
  5. passat flashing dash lights
    By minty0_10 in forum Passat - Archive Topics
    Last Post: 25-11-2006, 11:18 PM
