Thread: Brake pad warning
  1. Brake pad warning
    Jul 2006
    Any Techies out there advise on brake pad warning activates iraticley. Vehicle T4 late 1999. I believe it to be connector on the loom N/S/F. Is there a quick fix or will the loom have to be repaired/replaced?
  2. Re: Brake pad warning
    Hi If the fault is intermittent, then it can not be other than a bad connection,the most likely place is the connector on the shock absorber.The pins in these contacts corrode.You can remove the connector if not repairable and solder the wires,and insolate them.You can if you want code the dash panel insert, removing the brake pad warning function
  3. Re: Brake pad warning
    Jul 2006
    Cheers Kenney
    When you say solder do you mean link the two together or or just cut out the plug & socket
    Coding the dash I take it being a dealer function
  4. Re: Brake pad warning
    Cut the wires and cut out the plug & socket and solder or (join the wires),which will be easier to replace the pads next time around.Just make sure they are well insolated.The dash panel can be recoded with Vag-com
  5. Re: Brake pad warning
    Jul 2006
    Ta Will give it a go
  6. Re: Brake pad warning
    Jul 2006
    Found fault in the loom just as it leaves chassis it flexes there and had gone open circuit . Spliced it back together now OK thanks
  1. Brake Warning Light On
    By vtskier in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 23-03-2008, 09:27 AM
  2. brake & warning lights
    By mark williams in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 12-02-2008, 03:38 PM
  3. Red Brake warning
    By dancerdave in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 17-12-2007, 12:37 PM
  4. Brake Pad Warning Light
    By darkskies in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 20-11-2007, 11:26 PM
  5. DIS Brake Fluid Warning with ABS warning light
    By radar1022 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 03-04-2007, 10:42 AM
