Thread: 1.9 Pd Tdi Engine
Results 1 to 10 of 16
  1. Question 1.9 Pd Tdi Engine
    Dec 2007
    Aberdeenshire, Scotland
    Hello,
    My car is currently comming up to its 10 k oil change.
    I was looking to buy miller XFE-PD 5W40 engine oil for it.
    But before i buy it does enyone know how much liters i have to buy to refill my engine ?
    I have a 2001 golf tdi Pd engine?
    Thans in advance
  2. Re: 1.9 Pd Tdi Engine
    Mar 2007
    you will need 5l for a full change with filter.
    Karl.
  3. Re: 1.9 Pd Tdi Engine
    Mar 2008
    4.5L
    Check your manual. It is very specific about not overfilling.
  4. Re: 1.9 Pd Tdi Engine
    Mar 2008
    Ipswich
    Use Mobil 1. You cannot beat it. I Have had cars with 200k+ miles on them, without the slightest bit of engine wear. You get what you pay for, but at least it won't fail and cause your engine to seize costing you loads more.
  5. Re: 1.9 Pd Tdi Engine
    7 Post(s)
    Quote Originally Posted by will95 View Post
    Even Mobil One is not good enough on the PD Engine. You must use a PD spec oil.
    Brief explanation;
    When developing the PD engine VAG realised that all currently available oils were not up to the job and would allow accelerated wear on the cab lobes for the unit injectors. With this known they commisioned the oil companies to produce an oil that would fit VAG's spec. If VAG could have got away with it, do you think they would have bothered with this. The answer is no, as it most likely cost them time and money in launching the PD unit.
  6. Re: 1.9 Pd Tdi Engine
    Aug 2007
    this may sound stupid but how do i know if mine is a PD engine? I have a golf mk 4 1.9 gt tdi 130 Y reg / march 2001
  7. Re: 1.9 Pd Tdi Engine
    133 Post(s)
    1986 Post(s)
    The 130 is a PD.
  8. Re: 1.9 Pd Tdi Engine
    Mar 2008
    Ipswich
    [quote=BigCol;154004]Even Mobil One is not good enough on the PD Engine.
    quote]
    Mobil 1 comes in two (main) grades. 15W30 and 5W40 which is the motorsport one. Are you telling me that even the 5W40 is not up to the job? If so I'd better get a change quick!
  9. Re: 1.9 Pd Tdi Engine
    Aug 2007
    two easy to find oils i have found that are PD spec are Castrol Edge turbo diesel ( make sure you get the right one - it says on the front i think, if not on the back!) and also i see that Halfords now do one that is ok for PD engines. Proberly not quite as good but if money is tight, it's alot better than using a non 'PD' oil
  10. Re: 1.9 Pd Tdi Engine
    Mar 2008
    Millers fully synthetic changed every 5000 miles.
  1. Engine Fans Start Up after Engine is Switched off??
    By batman in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-08-2009, 02:15 PM
  2. Replies: 7
    Last Post: 09-04-2008, 10:37 PM
  3. Changing worn transporter TDI engine to Golf engine?
    By flyin-turd in forum The Commercial Range
    Last Post: 18-01-2008, 12:28 AM
  4. A4 Engine support to replace engine mounts
    By JScribner in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-07-2007, 03:57 AM
  5. engine drop - engine mountng bolts sheer
    By shazzander in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 26-04-2007, 03:29 PM
