Thread: Golf alternator pulley fell off!
  1. Golf alternator pulley fell off!
    Mar 2008
    Hello,
    I managed to lose my alternator belt pulley whilst driving. The belt which I believe is called a serpentine belt, is still intact. I lost power steering and the battery light came on when it happened, but I continued by 30 mile journey regardless.
    I have searched around but cannot find the part or even find what it's really called. Does anyone know where I can get a pulley from? Please, other than the main dealer.
  2. Re: Golf alternator pulley fell off!
    S Wales
    Hello mate.
    I'm a PLC Technician for Bosch and would possibly be able to get you a pulley.
    If you can get the part number of the alternator, i'd then get up a bill of materials and see if we make the alternator and then if i'd be able to get a pulley. You'd also need a spline bit aswell to fix the pulley secure.
    An example of a alternator part number is "0124 555 055" it will be stamped on the protective cap, the opposite end to the pulley.
    Let me know..
  3. Re: Golf alternator pulley fell off!
    Quote Originally Posted by drfe11a View Post
    Hello,
    Where are you based? I may know someone local who can supply.
    Otherwise just walk into any motor factor and ask them. If they look at you blankly, tell them to ring FPS as they have them on the shelf and can identify - and supply tools if needed.
    Let the factor identify the part - then if its the wrong one, its their fault and youll get it replaced. If you give them the part number, you have no comeback
    2019 Urus, 2020 RS7
    2014 RS6, 2018 RS5, 2016 RS3, 2019 RS3
    2011 RS5, 2008 S5 V8
    2007 A4 2.0, 2008 Passat 2.0 TDI
    2005 Bora 1.9 TDI, 2000 Bora 1.6 , 1989 Polo 1.4
  1. Alternator pulley clutch
    By vincentbob in forum Passat - B5 Forum - 1997 -2005
    Last Post: 10-03-2009, 02:10 PM
  2. Alternator pulley clutch again
    By dc2 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 27-03-2008, 04:25 PM
  3. Alternator pulley
    By Andy N.I in forum Passat - B5 Forum - 1997 -2005
    Last Post: 28-01-2008, 10:14 PM
  4. A6 1.9TDI Alternator Pulley
    By johnnywishbone in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 28-10-2007, 11:46 AM
  5. 03 tdi alternator pulley
    By jeevoe999 in forum New Member Introductions
    Last Post: 26-02-2007, 12:38 AM
