Thread: audi 80 avant M plate
  1. audi 80 avant M plate
    Mar 2008
    new ecu fitted but problems with immobiliser. engine turns over and sparks but cuts out.
  2. Re: audi 80 avant M plate
    Mar 2008
    why was the ecu replaced ? was it to fix the cutting out problem or was it for something else.
    Immobilisers use a coil round the ignition barrel. with the key fitted, a signal from the coil is sent to the ECU.
    If the ecu gets the correct value, the car runs fine. If it's wrong, the immobiliser will cut in.
    The problem usually lies with either the key or the coil, not the ECU.
    1991 90 quattro 20v sport
    1987 Coupe quattro
    1988 quattro
  1. Audi A4 2.0 TDI S-Line full spec (B7 / 2007 plate)
    By kamg in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 30-03-2008, 09:08 PM
  2. Audi a3 54 plate alloys aftermarket
    By paulvwturbo in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 13-11-2007, 10:47 PM
  3. Replies: 4
    Last Post: 11-09-2007, 11:09 AM
  4. Will a 54 plate tdi 130 turbo fit a 51 plate 130 tdi???????????
    By wasabi in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 20-06-2007, 05:27 PM
  5. The new Audi A6 Avant
    Last Post: 20-11-2004, 09:09 PM
