Thread: B6 Bulb failiure light on DIM
  1. B6 Bulb failiure light on DIM
    Mar 2008
    Wiltshire
    Morning all.
    My B6 A4 has started showing a picture of a bulb in the DIM with a cross through it.
    It also tells me "rear left bulb".
    I guess that this means that one of the bulbs is out, but a quick 2 minute inspection of side lights and brake lights reveals nothing?
    Any ideas?
    Is it telling me about other bulbs such as fog even though they arent switched on?
    Rav
    2003 (MY) Audi A4 1.9TDI SE.
  2. Re: B6 Bulb failiure light on DIM
    Dec 2007
    it will tell you about bulbs that have failed even if they are turned off
  3. Re: B6 Bulb failiure light on DIM
    Mar 2008
    Wiltshire
    Sounds good. I will check to see which bulbs have failed then.
    Out of interest is this done by resistance then?
  4. Re: B6 Bulb failiure light on DIM
    Dec 2007
    i think voltage i know if you swap to LEDS with out a filter it sends your dis mad
  5. Re: B6 Bulb failiure light on DIM
    Dec 2007
    Aberdeenshire, Scotland.
    Rav,
    I had the same problem with my 03 Avant, kept getting 'check rear left bulb'. On checking brake lights etc, all working fine. It kept doing this intermittently until eventually the rear left brake bulb did fail a few days later.
    I think it can tell if a bulb is failing due to voltage or current fluctuations.
    There is a sticky at the top of this part of the forum posted by Rick T that explains how to access the bulbs on A4s.
  6. Re: B6 Bulb failiure light on DIM
    Mar 2008
    Wiltshire
    Thanks chaps. Will look into this.
    Just been outside and thought - How do i access the bulbs?
    Sticky on top...Brilliant !!
  1. dash light bulb
    By neilg in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 06-12-2007, 08:04 PM
  2. light bulb legalities....
    By Eshrules in forum Chat - Anything with wheels
    Last Post: 31-08-2007, 12:53 PM
  3. Head light bulb
    By daveyswan in forum Audi A4 - Archive Topics
    Last Post: 18-04-2007, 11:58 PM
  4. A6 2.5 Tdi Instrument Failiure
    By jargonking in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 24-01-2007, 10:42 AM
